Graphics don't display on Linux
New Altair Community Member
Updated by Jocelyn
Hi !
Just starting with RapidMiner. Can't get any graphic displayed as shown in the tutorial. Blank space in the middle area, when the tutorial is showing nice bar charts...
I have tried several (3) recent flavors of Ubuntu on different machines. Same result.
Note that everytime, I had to remove Java 11 to Java 8 to get things starting...
Any suggestion ???
Eric
1 - 10 of
101
Hi Martin & Marco,
Thanx for your prompt replies :
- Martin : I think you mean jxbrowser since I can't find anything on fxbrowser... ?
Note thatt I have Firefox and Chromium installed
- Marco : I tried on standard Ubuntu 18.10 and 19.10, Gnome 3 and XFCE, as well as Ubuntu Mate 19.10 (Gnome 2 I think).
All with same frustrating result...
Eric
Hi again,
Upon startup :
In the log file, I get one single warning :
WARNING: Plugin initializer com.rapidminer.extension.cloud.connectivity.PluginInitCloudConnectivity.initGui of Plugin Cloud Connectivity caused an error: null
then a bunch of java related explanations.
On the GUI, I get a message "Incompatible extension during startup" Cloud Connectivity Version 9.5.0
If I ignore the message, then the prgram starts normally.
Thank you
Eric
Hi again and again...
1/ Made a complete new fresh installation of Ubuntu 19.10, with all latest updates. Nothing else
2/ Installed JRE 8 :
openjdk version "1.8.0_232"
OpenJDK Runtime Environment (build 1.8.0_232-8u232-b09-0ubuntu1.1-b09)
OpenJDK 64-Bit Server VM (build 25.232-b09, mixed mode)
3/ Setup ClassPath :
source /etc/environment => echo $JAVA_HOME => /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/
4/ Installed RapidMiner fresh
Still same situation ...
RapidMiner starts, but no graphics ...
Same warning as before in the log.
Desperation starting to raise ...
Eric
Updated by Marco_Boeck
Hi,
Ubuntu 18+ has a problem with the current version and the Chromium browser, we are aware of that. Though so far it was related to KDE desktop, but others may be affected as well. That particular issue should be fixed by the upcoming RapidMiner 9.6 release (early Feb).
But just to confirm it is actually said problem, would you mind uploading the entire rapidminer-studio.log from your HOME/.RapidMiner folder?
Regards,
Marco
Regards,
Marco
thanks @Marco_Boeck and @mschmitz. Are there any workarounds until 9.6 is released? Maybe @BalazsBarany has a clever idea?
Scott
Scott
Hi,
for me the Amazon Corretto JVM 8 (Amazon distribution of OpenJDK) works best.
https://docs.aws.amazon.com/corretto/latest/corretto-8-ug/downloads-list.html
I don't have any problems with charts or graphics on my Kubuntu machine.
Regards,
Balázs
Regards,
Balázs
One common issue maybe that your linux does not have fxbrowser installed. Can you check this please?
