🎉Community Raffle - Win $25
Join and Win
error while resolving connection
User: "saba76"
New Altair Community Member
Updated by Jocelyn
Hi guys!
Is there anybody who can help me by this error?
I've converted the connection but it is not fixed.
1 - 4 of 41
    User: "kayman"
    Accepted Answer
    The Twitter operator is expecting a saved connection, which you probably don't have. Disconnect the con-in port and you should get additional options with your operator where you can provide the Twitter settings
    User: "saba76"
    OP
    Updated by saba76
    @kayman
    Thanks a lot.
    User: "Marco_Boeck"
    Accepted Answer
    Hi,
    You have 2 options on using connections:
    1. You just add the operator, and don't connect the "con" input port on the left side of the operator box. Then you can select the connection entry in the operator parameters.
    2. You can drag the connection from the repository into the process, and connect that with the "con" input port of the operator.
    You can see that here in our docs: https://docs.rapidminer.com/latest/studio/connect/cloud/twitter.html#search-phrase
    Regards,
    Marco
    User: "saba76"
    OP
    @Marco_Boeck
    Thanks a million.
