Deep Learning Extension Source Code?
Hello,
I am looking for the source code of the Deep Learning Extension. In particular I am intereseted of how to bundle the different platform dependent jars into the extention jar and the load it dynamically.
Since the Extension is labeled as AGPL Licence I suspect the code should be available. Unfortunately I could only find a very old repo from rapidminerchina here: https://github.com/LostSummer233/rapidminer-extension-dl4j-pack
Where can I find the source of the current version? Any help to solve the mystery of loading the nd4j stuff dynamically in RapidMiner would be appreciated!
Thanks!
1 - 4 of
41
@pschlunder any insights here?
hi @User146561 and @varunm1 the folks in Dortmund are working on this. I gave them a gentle nudge this morning.
Scott
Scott
Hi @User146561,
the code is currently only handed out on request. Please contact me via DM with your E-Mail address so I can provide you access to the code.
We've created our own loading mechanism for switching between backends during runtime. If you have questions about that @jczogalla can help.
Hope this helps.
Philipp
1 - 1 of
11
Hi @User146561,
Hope this helps.
Philipp
