🎉Community Raffle - Win $25
Join and Win
Operators cannot use (and no compatible extension can be found) after update to newer version. Tks!
User: "hmhsing"
Altair Community Member
Updated by Jocelyn
1 - 5 of 51
    User: "sgenzer"
    Altair Employee
    hi @hmhsing I think you only posted the first line of your XML. Perhaps you meant to post the whole thing?
    User: "hmhsing"
    OP
    Sorry about this, I have attached the whole XML this time. I am using 9.5, when I import the process I saved probably in version 8.2, some of the operators cannot be used (in red). I tried to search for missing extension on market place but shows "No compatible version of the selected extension could be found".  I hope to retrieve the script I wrote in the "old" Execute Python before.  Thanks for the help!
    User: "hmhsing"
    OP
    User: "varunm1"
    New Altair Community Member
    Hello @hmhsing
    Can you provide .rmp file by exporting your process (File --> Export process)?
    Your XML is not posted and a better alternative is to provide .rmp file so that we can import the process.
    User: "hmhsing"
    OP
    I have attached the .rmp file, hope this time works. The Execute Python operator is in the subprocess of Loop Example. Thank you very much!
