🎉Community Raffle - Win $25
Join and Win
Problem about Rapidminer Studio (Linux Version)
User: "Rapidminerpartner"
New Altair Community Member
Updated by Jocelyn
Hello, everyone
From today, I am using Rapidminer Studio for Linux
I installed it on CentOS 7 and java 1.8 is running on CentOS.
But when I start Rapidminer
there are several error messages and lots of warning
and if I try to edit text to edit boxes in Rapidminer UI
Rapidminer stopped and it says (on console)
"Could not find conda command in the current search path
Please add the folder, which contains the conda executable."
I captured and attached the error log messages
Please help me with this problem
Thank you and have a nice day, everyone
1 - 7 of 71
    OP
    Hello, I just installed anaconda3 to CentOS but still Rapidminer freezes when I try to fill something in edit boxes. On console, it is said "Rapidminer stopped".
    User: "Marco_Boeck"
    Hi,
    I see two things:
    1. You need to install libxss1 as apparently CentOS does not have it by default.
    2. You need to have JavaFX available. Without JavaFX, you will not be able to edit connections as their UIs depend on it.
    Regards,
    Marco
    OP
    Updated by Rapidminerpartner
    Hello, Marco. Thank you for you guide.
    I will try as you said
    But by the way, I have one more issue.
    Now when I try to run Rapidminer(Linux), there's message saying
    RAPIDMINER HOME is not set ...
    and Rapidminer is running but the Graphic UI is not showing
    my java on CentOS is Java 1.8
    Could you please help me with this, why this is happening.??
    Thank you..!
    User: "Marco_Boeck"
    Hi,
    That does prevent you from updating, but has nothing to do with the UI. Please use Java 8 with JavaFX, and then if you still have issues, please post the full startup logs (found in user_home/.RapidMiner folder, they are called rapidminer-studio.log and launcher.log).
    Regards,
    Marco
    OP
    Hello, Marco
    I just installed libXss.so.1 and JavaFX 11
    now when I touch some button, the required dialog box appears,
    but still, it freezes (stops) when I select one item in the dialog box.
    I attached the log files
    Thank you.
    User: "Roe"
    Hi. For the RM home is not set problem, it is that Java 8 is required specifically (not even newer versions). Had the same problem (on Ubuntu).
    Soln:
    1. sudo apt install openjdk-8-jdk openjdk-8-jre # to install required jdk.
    2. sudo update-alternatives --config java # to view your jdk versions and choose a comaptible one.
    3. select the version with the java8 (1081) in my case. # Use the number in the first column.
    4. cd to location of RM. # go to location of RM using terminal.
    5. ./RapidMiner-Studio.sh # this will start installation. Be patient.
    User: "Cyborge"
    Hello Roe ,
    I'm trying to do the same ,but it's getting stuck on "initializing check"
