🎉Community Raffle - Win $25
Join and Win
Estimation of process duration
User: "Muhammed_Fatih_"
New Altair Community Member
Updated by Jocelyn
Hello together,
is there a possibility to estimate the time duration of a process before starting or during the process execution? Especially for bigger processes that take a lot of time like for example dimensionality reduction within Text Mining approaches, which can f.e. take more than one day, this would be very helpful.
I've seen that RapidMiner provides an extension called "Jackhammer Extension". The problem is that the extension tracks the time after having executed the process.
Thank you in advance for your answers!
Muhammed
1 - 3 of 31
    User: "[Deleted User]"
    @Muhammed_Fatih_
    Hello
    My suggestion to you is parallel processing. If your data need one day for process it is better to use parallel processing.
    I hope this helps
    mbs
    OP
    Hello,
    thank you for your answer. I think the problem in my case is that there is no parallelity needed here. The SVD itself is a single chained process.
    Do you see a possibility to parallelize the attached process?
    OP
    Are there other possibilites to estimate the process duration within RapidMiner?
