Trial version can't connect to marketplace / install
1 - 5 of
51
Hello @cgeib79
This might be due to some firewall that is blocking your marketplace connection. There is another way to install extensions. You can download jar files and then place them in .rapidminer folder. Please see below threads from @sgenzer that helps you installing an extension without a marketplace.
https://community.rapidminer.com/discussion/comment/60030#Comment_60030
https://community.rapidminer.com/discussion/53848/rapidminer-studio-files-what-is-on-my-computer-and-where
Hope this helps
Hope this helps
Hello @cgeib79
The .rapidminer folder is in "C:\Users\varun\.RapidMiner" for my PC. Look at your user folders to see where your .rapidminer folder is in.
I have the same problem. How can I solve it?
Thank you in advance for your suggestion
