Training r2 and error
mb223223
mb223223 New Altair Community Member
edited November 2024 in Community Q&A
As I know the error and r2 appeared in the Results is belonging to testing error. How can I have both training and testing error in the Results in a process?
Best
Best Answer
  • varunm1
    varunm1 New Altair Community Member
    edited September 2019 Answer ✓
    Hello  @mb223223
    Generally, we don't recommend looking into train error as the models overfit most of the times, but if you have any specific requirement here is the sample process to get training and testing error either using a split validation or cross-validation. I also attached the sample process files that you can import into rapidminer from File --> Import Process so that you can run them as well.
    Split Validation: Training & Testing Error
    Cross-Validation Training and Testing Error: This is inside cross-validation operator.
    Hope this helps. Please inform if you need more information.
Answers
  • varunm1
    Hello  @mb223223
  • mb223223
    Hi Dear Varun
    Thanks indeed for your reply and unique solution.
    Best Wishes
Welcome!
Welcome!
