Altair RISE
Nominate Yourself Now!
attribute selection operator
User: "mansour_ebrahim"
New Altair Community Member
Updated by Jocelyn
Dear All
I have to make sub-datasets from the main one (I mean selecting subsets of attributes from the original dataset with more than 1000 columns or attributes). I have the name of attributes but cannot past them into the Select Attribute Subset area. Does anybody have any good suggestion to avoid selecting them one by one; doing that is really painful and tedious
Best wishes and regards.
Mansour
1 - 3 of 31
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    attached is one way of filtering "by a list"
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"><br>  <context><br>    <input/><br>    <output/><br>    <macros/><br>  </context><br>  <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"><br>    <parameter key="logverbosity" value="init"/><br>    <parameter key="random_seed" value="2001"/><br>    <parameter key="send_mail" value="never"/><br>    <parameter key="notification_email" value=""/><br>    <parameter key="process_duration_for_mail" value="30"/><br>    <parameter key="encoding" value="SYSTEM"/><br>    <process expanded="true"><br>      <operator activated="true" class="utility:create_exampleset" compatibility="9.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="246" y="238"><br>        <parameter key="generator_type" value="comma separated text"/><br>        <parameter key="number_of_examples" value="100"/><br>        <parameter key="use_stepsize" value="false"/><br>        <list key="function_descriptions"/><br>        <parameter key="add_id_attribute" value="false"/><br>        <list key="numeric_series_configuration"/><br>        <list key="date_series_configuration"/><br>        <list key="date_series_configuration (interval)"/><br>        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br>        <parameter key="time_zone" value="SYSTEM"/><br>        <parameter key="input_csv_text" value="att&#10;Wind&#10;Temperature"/><br>        <parameter key="column_separator" value=","/><br>        <parameter key="parse_all_as_nominal" value="false"/><br>        <parameter key="decimal_point_character" value="."/><br>        <parameter key="trim_attribute_names" value="true"/><br>      </operator><br>      <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="238"><br>        <list key="function_descriptions"><br>          <parameter key="Weight" value="1"/><br>        </list><br>        <parameter key="keep_all" value="true"/><br>      </operator><br>      <operator activated="true" class="converters:example_set_2_weights" compatibility="0.5.000" expanded="true" height="82" name="ExampleSet to Weights" width="90" x="514" y="238"><br>        <parameter key="name_attribute" value="att"/><br>        <parameter key="weights_attribute" value="Weight"/><br>      </operator><br>      <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="246" y="85"><br>        <parameter key="repository_entry" value="//Samples/data/Golf"/><br>      </operator><br>      <operator activated="true" class="select_by_weights" compatibility="9.3.001" expanded="true" height="103" name="Select by Weights" width="90" x="648" y="136"><br>        <parameter key="weight_relation" value="greater equals"/><br>        <parameter key="weight" value="1.0"/><br>        <parameter key="k" value="10"/><br>        <parameter key="p" value="0.5"/><br>        <parameter key="deselect_unknown" value="true"/><br>        <parameter key="use_absolute_weights" value="true"/><br>      </operator><br>      <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/><br>      <connect from_op="Generate Attributes" from_port="example set output" to_op="ExampleSet to Weights" to_port="example set"/><br>      <connect from_op="ExampleSet to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/><br>      <connect from_op="Retrieve Golf" from_port="output" to_op="Select by Weights" to_port="example set input"/><br>      <connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/><br>      <portSpacing port="source_input 1" spacing="0"/><br>      <portSpacing port="sink_result 1" spacing="0"/><br>      <portSpacing port="sink_result 2" spacing="0"/><br>    </process><br>  </operator><br></process><br><br>
    OP
    Hi Martin,
    Many thanks. But the operator ExampleSet to Weight is not showing in my rapidminer, which version are you currently using?
    Regards.
    Mansour
    User: "tftemme"
    Accepted Answer
    Hi @mansour_ebrahim
    The ExampleSet to weight operator is from the converters extension. Please install it from the Marketplace.
    Best regards,
    Fabian
