<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="246" y="238"><br> <parameter key="generator_type" value="comma separated text"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="input_csv_text" value="att Wind Temperature"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="238"><br> <list key="function_descriptions"><br> <parameter key="Weight" value="1"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <operator activated="true" class="converters:example_set_2_weights" compatibility="0.5.000" expanded="true" height="82" name="ExampleSet to Weights" width="90" x="514" y="238"><br> <parameter key="name_attribute" value="att"/><br> <parameter key="weights_attribute" value="Weight"/><br> </operator><br> <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="246" y="85"><br> <parameter key="repository_entry" value="//Samples/data/Golf"/><br> </operator><br> <operator activated="true" class="select_by_weights" compatibility="9.3.001" expanded="true" height="103" name="Select by Weights" width="90" x="648" y="136"><br> <parameter key="weight_relation" value="greater equals"/><br> <parameter key="weight" value="1.0"/><br> <parameter key="k" value="10"/><br> <parameter key="p" value="0.5"/><br> <parameter key="deselect_unknown" value="true"/><br> <parameter key="use_absolute_weights" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_op="ExampleSet to Weights" to_port="example set"/><br> <connect from_op="ExampleSet to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/><br> <connect from_op="Retrieve Golf" from_port="output" to_op="Select by Weights" to_port="example set input"/><br> <connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
