🎉Community Raffle - Win $25
Join and Win
Finding Correlations
User: "Papad"
New Altair Community Member
Updated by Jocelyn
Hello everyone,
I want to make a flow in order to find correlations between some attributes of a machine.
The attributes are like speed, pressure, alarms etc.
How can I do it?
Also, suppose that I have live data. If I use historical data like all these, is it possible to create a neutral network
in order to find the next alarms in the future?
Any ideas for other kind of modeling are welcome.
Thanks in advance.
1 - 2 of 21
    User: "varunm1"
    Accepted Answer
    Updated by varunm1
    Hello @Papad
    There is a correlation matrix operator that will provide us with the correlation between different attributes in a dataset.
    Coming to the neural network, you can train the network on historical data and feed the live data to make predictions.
    Please inform if you need more information.
    Thanks
    User: "lionelderkrikor"
    Hi @Papad,
    A good starting point, if you want to perform some predictive maintenance, is the process :
    "Predictive Maintenance on Turbofan engines" in the "Community Samples" / "Community Real Worls Use Cases".
    Regards,
    Lionel
