Running out of features during feature selection
I am stumbling upon the same error again and again while using FEATURE SELECTION operator with GLM learner inside. It starts with 56 features and pretty fast literally runs out of features each time I am trying to run the process.
These are GLM settings:
These are feature selection settings:
Please advise. I can also provide any additional information if needed.
Thanks!
I think I shouldn't have constant features as those were removed beforehand while cleaning the data. As for collinearity, I need to re-check this once again; anyway I will also try to uncheck the corresponding option as well.
I am getting back to this thread as I have faced the problem again.
Previously I have disabled removing collinear columns by nested GLM and this helped, so it helped and the process worked OK.
This time I have run into it again and found out that there was actually one constant column in my data after filtering the smaller subset for feature selection.
Hence my question, can't feature selection operator just ignore such columns, as it can happen eventually as in my case, but the error message itself seems too confusing actually?
Thanks!
Yeah, the error message is bad indeed. Unfortunately there is nothing we can do about this because we do not "own" that particular part of the code... :-( I am personally a bit torn on the constant handling here though. If we just keep it in, we avoid the error in this particular case but it kind of bugs me that a feature selection, which is supposed to get rid of the weak features, forces to keep constant column in. It kind of defeats the purpose.... also because it is really undocumented / special behavior of the H2O learner here we would need to work around...
So I actually would prefer to keep it the way it is but that would require you to use a Remove Useless Attributes operator before. Last option would be to remove all constant features automatically BEFORE we start the feature selection (and throw an error if that removes all columns), but that makes this a bit implicit which is not great either...
Any opinions on this?
https://community.rapidminer.com/discussion/55390/forward-selection-error-thrown#latest
Ingo
Ingo
