How do you update redshift database through rapidminer?
I get a database error when I try to use the "update database" operator.
"Database error occurred: ERROR: type "e" does not exist.
The JDBC driver has thrown an SQLException. This may because of a lack of privileges, wrong table name or url and similar problems. Please note that some databases are case sensitive. Details are given in the message."
Anyone have a step by step guide for updating redshift database? It's definitely not the wrong table name, I have the appropriate permissions and the connection was tested (and works).
For simplicity purposes, just including three operators below:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="jdbc_connectors:read_database" compatibility="9.2.001" expanded="true" height="68" name="Read Database" width="90" x="179" y="136">
<parameter key="define_connection" value="predefined"/>
<parameter key="connection" value="Redshift_VS"/>
<parameter key="database_system" value="MySQL"/>
<parameter key="define_query" value="query"/>
<parameter key="query" value="SELECT * FROM "rm_schema"."pre_industry_assignment""/>
<parameter key="use_default_schema" value="true"/>
<parameter key="table_name" value="pre_industry_assignment"/>
<parameter key="prepare_statement" value="false"/>
<enumeration key="parameters"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="187">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attribute" value=""/>
<parameter key="attributes" value="ctr"/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="attribute_value"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="time"/>
<parameter key="block_type" value="attribute_block"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="value_matrix_row_start"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
</operator>
<operator activated="true" class="jdbc_connectors:update_database" compatibility="9.2.001" expanded="true" height="68" name="Update Database" width="90" x="715" y="136">
<parameter key="schema_name" value="rm_schema"/>
<parameter key="table_name" value="post_industry_assignment"/>
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="ctr"/>
<parameter key="attributes" value=""/>
</operator>
<connect from_op="Read Database" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Update Database" to_port="input"/>
<connect from_op="Update Database" from_port="through" to_port="result 1"/>
</process>
</operator>
</process>
