Altair RISE
Nominate Yourself Now!
Split preformatted text (of web page) on paragraphs
User: "philipp25"
New Altair Community Member
Updated by Jocelyn
Hello,
I crawled multiple pages with the "get Pages"-Operator (Webmining Extension). All of the text of the website is in a <pre>-HTML-tag.
I want to cut the preformatted-text by the paragraphs. The "get Content"-Operator extracts the text perfectly, but destroys the formatting.
Any solution?
Thanks!
1 - 7 of 71
    User: "Telcontar120"
    You could split the text up by paragraph using the Cut Document operator and then use Extract Content operator on the resulting paragraphs, and then join everything back together.
    User: "philipp25"
    OP
    Updated by philipp25
    Thanks! But first I have to extract the text from the <pre> don't I?  I would post a Link, but my RM-Account seems to be too new :)
    <body>
        <pre>
                  preformatted text
                  paragaph
                 performatted text
        </pre>
    </body>
    Okay I got further. I extracted the text into an attribute and it looks like this:
    text
    text
    text2
    text2
    How do I split the text on each empty line / paragraph ?
    Cut Document should do the trick if you use regex for line breaks, or you could also do the cut before you remove the html and use the html code instead.
    User: "sgenzer"
    Altair Employee
    @philipp25 I just boosted your user acct - you can post links now.
    Scott
    User: "philipp25"
    OP
    It just does not work...
    Here is my process:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="112" y="34">
            <parameter key="text" value="text&#10;text&#10;&#10;text&#10;text&#10;&#10;"/>
            <parameter key="add label" value="false"/>
            <parameter key="label_type" value="nominal"/>
          </operator>
          <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="313" y="34">
            <parameter key="query_type" value="Regular Expression"/>
            <list key="string_machting_queries"/>
            <parameter key="attribute_type" value="Nominal"/>
            <list key="regular_expression_queries">
              <parameter key="line_breaks" value="\n\s"/>
            </list>
            <list key="regular_region_queries"/>
            <list key="xpath_queries"/>
            <list key="namespaces"/>
            <parameter key="ignore_CDATA" value="true"/>
            <parameter key="assume_html" value="true"/>
            <list key="index_queries"/>
            <list key="jsonpath_queries"/>
              <connect from_port="segment" to_port="document 1"/>
              <portSpacing port="source_segment" spacing="0"/>
              <portSpacing port="sink_document 1" spacing="0"/>
              <portSpacing port="sink_document 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/>
          <connect from_op="Cut Document" from_port="documents" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "SGolbert"
    Cut Documents with XPath is also a great option, as it takes advantage of the HTML structure. Both regex and XPath are kind of unruly tools, so you will have to choose your poison.
    Regards
    Sebastian
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    @philipp25 you need to define what you want to KEEP in the Cut Document regex expression. All you're keeping are the line breaks :smile: See this process:
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34">
          </operator>
          <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="179" y="34">
              <parameter key="line_breaks" value="text\n"/>
            </list>
            </process>
          </operator>
        </process>
      </operator>
    </process>
    Scott
