<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34"> <parameter key="text" value="text text text text "/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="179" y="34"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"> <parameter key="line_breaks" value="text\n"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> <process expanded="true"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
