Exporting Word frequency to excel
User: "AnumBse16"
New Altair Community Member
Updated by Jocelyn
Hi!
I'm trying to implement the attached paper.I'm not getting the frequency list like the one in the picture.My process is given below, kindly guide
@bhupendra_patil @sgenzer
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000">
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="9.2.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
        <parameter key="excel_file" value="D:\uni stuff\6th semester\AI\project\Links.xlsx"/>
        <parameter key="sheet_selection" value="sheet number"/>
        <parameter key="sheet_number" value="1"/>
        <parameter key="imported_cell_range" value="A1"/>
        <parameter key="first_row_as_names" value="true"/>
        <list key="annotations"/>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
        <list key="data_set_meta_data_information">
          <parameter key="0" value="Link.true.polynominal.attribute"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="false"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      </operator>
      <operator activated="true" class="web:retrieve_webpages" compatibility="9.0.000" expanded="true" height="68" name="Get Pages" width="90" x="179" y="34">
        <parameter key="link_attribute" value="Link"/>
        <parameter key="random_user_agent" value="false"/>
        <parameter key="connection_timeout" value="10000"/>
        <parameter key="read_timeout" value="10000"/>
        <parameter key="follow_redirects" value="true"/>
        <parameter key="accept_cookies" value="none"/>
        <parameter key="cookie_scope" value="global"/>
        <parameter key="request_method" value="GET"/>
        <parameter key="delay" value="none"/>
        <parameter key="delay_amount" value="1000"/>
        <parameter key="min_delay_amount" value="0"/>
        <parameter key="max_delay_amount" value="1000"/>
      </operator>
      <operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="246" y="187">
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
      </operator>
      <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="380" y="85">
        <parameter key="create_word_vector" value="true"/>
        <parameter key="vector_creation" value="Term Frequency"/>
        <parameter key="add_meta_information" value="true"/>
        <parameter key="keep_text" value="true"/>
        <parameter key="prune_method" value="none"/>
        <parameter key="prune_below_percent" value="3.0"/>
        <parameter key="prune_above_percent" value="30.0"/>
        <parameter key="prune_below_rank" value="0.05"/>
        <parameter key="prune_above_rank" value="0.95"/>
        <parameter key="datamanagement" value="double_sparse_array"/>
          <operator activated="true" class="web:extract_html_text_content" compatibility="9.0.000" expanded="true" height="68" name="Extract Content" width="90" x="112" y="34">
            <parameter key="extract_content" value="true"/>
            <parameter key="minimum_text_block_length" value="5"/>
            <parameter key="override_content_type_information" value="true"/>
            <parameter key="neglegt_span_tags" value="true"/>
            <parameter key="neglect_p_tags" value="true"/>
            <parameter key="neglect_b_tags" value="true"/>
            <parameter key="neglect_i_tags" value="true"/>
            <parameter key="neglect_br_tags" value="true"/>
            <parameter key="ignore_non_html_tags" value="true"/>
          </operator>
          <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34">
            <parameter key="mode" value="non letters"/>
            <parameter key="characters" value=".:"/>
            <parameter key="language" value="English"/>
            <parameter key="max_token_length" value="3"/>
          </operator>
          <operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="380" y="34">
            <parameter key="transform_to" value="lower case"/>
          </operator>
          <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="136"/>
          <operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="581" y="289">
            <parameter key="min_chars" value="4"/>
            <parameter key="max_chars" value="25"/>
          </operator>
          <connect from_port="document" to_op="Extract Content" to_port="document"/>
          <connect from_op="Extract Content" from_port="document" to_op="Tokenize" to_port="document"/>
          <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
          <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
          <portSpacing port="source_document" spacing="0"/>
          <portSpacing port="sink_document 1" spacing="0"/>
          <portSpacing port="sink_document 2" spacing="0"/>
        </process>
      </operator>
      <operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="581" y="136"/>
      <operator activated="true" class="write_excel" compatibility="9.2.000" expanded="true" height="82" name="Write Excel" width="90" x="648" y="238">
        <parameter key="excel_file" value="D:\uni stuff\6th semester\AI\project\result.xlsx"/>
        <parameter key="file_format" value="xlsx"/>
        <parameter key="sheet_name" value="RapidMiner Data"/>
        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
        <parameter key="number_format" value="#.0"/>
      </operator>
      <connect from_op="Read Excel" from_port="output" to_op="Get Pages" to_port="Example Set"/>
      <connect from_op="Get Pages" from_port="Example Set" to_op="Data to Documents" to_port="example set"/>
      <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
      <connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
      <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
      <connect from_op="WordList to Data" from_port="example set" to_op="Write Excel" to_port="input"/>
    </process>
  </operator>
</process>
