If you are asking for a PhP API for rapidminer, I don't see anything available especially that can display results. The general way is to use rapidminer server for web services.
you definiely need the server for this. There are workarounds but they suck. You would basically have to have an external web service (something like Python's Flask) that triggers the command line of RM Studio. And Studio takes quite some time to load up . . .
You can run the process from command line
@mschmitz or @BalazsBarany might have some workaround for this.
Correct me if my understanding is not correct.
Thanks
