RapidMiner Server - Merge Attributes Error
I am running a process that includes the 'Merge Attributes' operator which runs fine in Studio but causes the following error when run on the server:
Error in executed process
The 'Merge Attributes' operator in the process executed by 'Execute impact' failed with: The dummy operator Merge Attributes (replacing operator_toolbox:merge) cannot be executed.
Process[1] (Process)
subprocess 'Main Process'
==> +- Execute impact[1] (Execute Process)
This error needs to be fixed before the current process can run.
1 - 6 of
61
- %PATH_TO_SERVER/home/resources/extensions/
- %PATH_TO_SERVER/home/job-agent-home/resources/extensions/
Merge Attributes is coming from the Operator Toolbox extension. You need to put the extension on the server to be able to use the operator.
Hi @Markus,
I have my extensions running by putting all the extension files in two locations:
As you say, this shouldn't be necessary, but better safe than sorry
Regards,
Sebastian
