1 - 4 of
41
Hi,
I am not 100% sure but I think I had this error before when I accidentally installed a 32 bit version of RapidMiner on a 64 bit system (or the other way round). Please make sure that you install the correct version of RapidMiner matching both your hardware and operating system.
Hope this helps,
Hope this helps,
Ingo
Hi @Rj_Chin ,
I faced this earlier as I installed different version of RM on my 64 bit machine. Also check your JDK, if possible try to reinstall both RM(32 or 64 based on your system) and JDK.
I am not sure if this is RM specific error cause I saw it with other softwares that run on java as well.
Thanks,
Varun
Thanks,
Varun
error code 1 is generally a failure without anything more. Can you check your launcher.log in $USER/.RapidMiner/ . This should provide more information.
Best,
Martin
