[SOLVED] Write Excel - how to write data to the same workbook but different shee
Hi,
I've got a couple of loop files operators reading excel and CSV files from within a zip file.
One of the steps in my process is writing the data into different sheets in Excel
My problem is that the write excel operator writes over the excel file rather than adding a sheet with a different name.
Any help would be greatly appreciated.
Cheers,
Edit: Solved - http://rapid-i.com/rapidforum/index.php/topic,6474.0.html
Cheers,
