🎉Community Raffle - Win $25
Join and Win
Flex Prep Tool - Motion View - giving error while creating .h3d flex body. How to resolve?
User: "Rohan Joshi"
Altair Community Member
Updated by Rohan Joshi
Invalid Node Selection!
Total Translation Warnings and Errors:
Warnings: 0
Errors: 1
child process exited abnormally
1 - 4 of 41
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hello Rohan
    Is there a fem file that you can share ? Also a screenshot of the Flexprep dialog before you hit OK with interface nodes and other fields filled in ?
    I suggest you to check the .out file to see if there are any specific messages from Optistruct, the solver that is used  for the flexbody creation.
    Regards
    Praful
    User: "Rohan Joshi"
    OP
    Hello Praful,
    Thanks for your quick response! Unfortunately, I cannot share the .fem file with you, however, I can share information/cards/sets etc from within the file with you as text entries.
    Following is a screenshot of Flexprep dialog, we have been using this to generate flex bodies in the past, however, this one is giving errors.
    The output thrown is the following:
    ** Altair Flexible Body Preprocessor **
    ** Flexible Body Modal Synthesis and Data Translation Software **
    ** from Altair Engineering, Inc. **
    ** Executable flexprep 2021.0.0.33
    ** Time of Build 18:16:28
    ** Date of Build Jan 14 2021
    ** Copyright (c) 1996-2020 Altair Engineering, Inc. All Rights Reserved.
    Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
    Decompilation or disassembly of this software is strictly prohibited.
    Warnings: 0
    Errors: 1
    Hope this helps you help me debug it! Please let me know if any further information is required, many thanks
    User: "Praful"
    Altair Employee
    Accepted Answer
    Updated by Praful
    Thanks for that screenshot.
    I can see 2 possible causes. You may try eliminating one by one
    A) The node number needs to be specified in either of the following format
    1. 511+512+513 (This is to specify an assorted list of nodes)
    2. 511:513  (This is to specify a range)
    3.  combination of 1 & 2. E.g. 6+8:15+67 <- includes node 6, 8 through 15 and 67
    Check if this solves the problem.
    B) I see your path contain spaces. Check if the problem goes away when you have files in path without space.
    Regards
    Praful
    User: "Rohan Joshi"
    OP
    Hi Praful,
    Thanks for pointing out that my syntax was wrong. I jumbled up between software, in other places, it was 511,512,513 here it was supposed to be 511+512+513 This has helped me resolve, can't believe it was such a stupid blunder on my end.
    Really appreciate your support in resolving this, thank you! Cheers :)
