🎉Community Raffle - Win $25
Join and Win
Deep Learning extension RELEASE thread
User: "pschlunder"
New Altair Community Member
Updated by Jocelyn
Last week we released a new Deep Learning extension along the RapidMiner Studio 9.0 update.
Find an overview of the initial feature set in this knowledge base article.
Please share problems and feedback in this thread along.
A few remarks and known issues up-front:
  • The 64-bit (standard) version of RapidMiner Studio is needed.
  • Currently only CUDA version 9.1 is supported due to extension size concerns. If you are working on a big project and need support for CUDA versions 9.0 or even 8.0, please contact us. Make sure CUDA is properly installed and its library added to your operating systems PATH variable.
  • Non-tabular data currently needs a new object (a tensor). This might be changed in the future.
  • Problems during extension loading might occur when MKL (e.g. from Anaconda) is on your system's PATH variable. If so, please remove the problematic folder (like Anaconda) for the Studio start from the PATH variable.
  • As the extension progresses we'll post learning material along the way. Until then please checkout the operator documentation and provided sample processes.
Find previous discussions here.
We're gradualy exploring native integrations of requested features. If one isn't available, yet, stay tuned or check out the Keras extension (thread, download).
Happy testing!
Philipp
1 - 9 of 91
    User: "Thomas_Ott"
    @pschlunder really cool guys. Is this extension supposed to replace the Keras extension or is this a new offshoot of it?
    User: "pschlunder"
    OP
    It is a completely new extension not based on Keras but on the Java library DL4J. Eventually all needed functionality from the existing Keras extension should be available as well as additional features.
    Regards,
    Philipp
    User: "hughesfleming68"
    Edit.... I found the explanation about why it might not install. Looking into it.
    Alex
    User: "varunm1"
    Updated by varunm1
    Irrelevant thread. Moved question to keras thread
    User: "varunm1"
    @sgenzer any support for my issue in the previous comment? Also, in this new platform can't we edit once a comment is posted? Thanks
    User: "sgenzer"
    Altair Employee
    hi @varunm1 sorry this is out of my KB. CC'ing the guru @pschlunder if he has time to answer...
    User: "jczogalla"
    @varunm1 sorry for being slightly off topic, but you should see a gear symbol on the top right corner of your post that let's you edit it. If you can't see it, maybe @sgenzer has to look at it. :smile:
    User: "varunm1"
    @jczogalla it works now.
    User: "sgenzer"
    Altair Employee
    yes apologies...still working the kinks out of the permissioning of this new community platform. Please send me a DM if you have issues.
    Scott
