🎉Community Raffle - Win $25
Join and Win
New Extension - Prescriptive Optimization
User: "MartinLiebig"
Altair Employee
Updated by Jocelyn
Hi everybody,
i just wanted to quickly inform you that i've released a new extension on prescriptive optimization to the market place: https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_prescriptive_analytics .
Sadly i don't have time to write a larger post on it, but i hope you still enjoy.
Best,
Martin
1 - 9 of 91
    User: "Thomas_Ott"
    New Altair Community Member
    @mschmitz I'm going to check this out and let you know what I think. On the surface, this definately fits a need I have. THANKS!!!
    Altair Employee
    OP
    @Thomas_Ott,
    make sure to use 9.0-BETA for it. Then you can run the example process which is somewhat self-explanatory.
    BR,
    Martin
    User: "sgenzer"
    Altair Employee
    FYI you can now hyperlink directly to the extension in the marketplace in Studio:
    rapidminer://extension/rmx_prescriptive_analytics
    Scott
    Altair Employee
    OP
    Hi All,
    i just released a new version with an additional optimization method.
    Any feedback? Maybe @Thomas_Ott ?
    BR,
    Martin
    User: "kypexin"
    Hi @mschmitz
    Wanted to check out tutorial process but not sure what dataset exactly it is referring to?
    There's no such dataset in standard repo templates:
    Repository_Browser_and__new_process__–_RapidMiner_Studio_Large_8_2_000___ATLL10050_local.png
    Altair Employee
    OP
    @kypexin,
    are you running 9.0?
    BR,
    Martin
    User: "kypexin"
    Yep I think it was the reason. I am still on version 8. Time to update... :)
    Altair Employee
    OP
    Hi Everyone,
    i've just released a new version of the extension to the marketplace.
    Version 0.1.4
    - Added "random", "input example" and "reference example" as a starting point options.
    - Removed the start setting in SimpleBounds. Please provide start values via input/reference exa. E.g. via Set Data.
    - Added a few better error messages for missing references, missing bounds etc
    Cheers,
    Martin
    Altair Employee
    OP
    Hi everybody,
    i've just released a new version which adds Powell as an optimization method.
    Here is the change log:
    Version 0.1.5
    - Added an option to add get candidate results. I.e. more than just the best solution
    - Evolutionary is now correctly using custom random seeds
    - Added Powell as an unbounded optimization method
    - A lot of code improvement for optimizer creation and parameter handling
