Altair RISE
Nominate Yourself Now!
round real values to the n-th decimal?
User: "Fred12"
New Altair Community Member
Updated by Jocelyn
hi,
is there any operator than can round or cut of some real number on the n-th decimal, e.g on the 5 number after the comma or so?
do this for one or any columns?
1 - 4 of 41
    User: "Telcontar120"
    I believe the "round" function available in generate attributes will do what you want quite easily!
    You also have the 'format numbers' operator but that will turn it into a nominal value.
    User: "SHSguy"
    How do I insert the round in the function expression?
    Tried using
    Function expression
    rand(round())
    also two separate function expressions no luck
    attribute 1 rand()
    attribute 1 round()
    also if maybe you know, how do I limit the random function between two numbers rand(1,5) does not work at all.
    Thank you in advance.
    User: "Edin_Klapic"
    Hi @SHSguy,
    I am not sure what you want to achieve in your first use case.
    If you want to round a random number the order of functions is wrong. It needs to be round(rand(),x) with x being the number of decimals to round to.
    Regarding your second question:
    The rand() function always delivers a floating point number between 0 and 1. So one possible solution would be
    rand()*5
     to get values between 0 and 5. If want them rounded to the next integer you would do
    ceil(rand()*5)
    ceil() rounds to the next integer "above"
    floow() rounds to the next integer "below"
    Happy Mining,
    Edin
    P.S.:
    An explanation to all function is given if you click on the i next to the function (see screenshot) image.png
    User: "SHSguy"
    Hi Edin,
    Thank you really appreciate the explanation.
    Best Regards,
    Nick
