hi,
is there any operator than can round or cut of some real number on the n-th decimal, e.g on the 5 number after the comma or so?
do this for one or any columns?
I believe the "round" function available in generate attributes will do what you want quite easily!
You also have the 'format numbers' operator but that will turn it into a nominal value.
How do I insert the round in the function expression?
Tried using
Function expression
rand(round())
also two separate function expressions no luck
attribute 1 rand()
attribute 1 round()
also if maybe you know, how do I limit the random function between two numbers rand(1,5) does not work at all.
Thank you in advance.
Hi @SHSguy,
I am not sure what you want to achieve in your first use case.
If you want to round a random number the order of functions is wrong. It needs to be round(rand(),x) with x being the number of decimals to round to.
Regarding your second question:
The rand() function always delivers a floating point number between 0 and 1. So one possible solution would be
rand()*5
to get values between 0 and 5. If want them rounded to the next integer you would do
ceil(rand()*5)
ceil() rounds to the next integer "above"
floow() rounds to the next integer "below"
Happy Mining,
Edin
P.S.:
An explanation to all function is given if you click on the i next to the function (see screenshot)
Hi Edin,
Thank you really appreciate the explanation.
Best Regards,
Nick
