Hello I used the Silhouette and cpcc criteria to evaluate clustering But as a result, the amount of unknow or infinite appears. What does it mean? Was clustering wrong? what is the reason? Thanks a lot
hello @maral welcome to the community! Some quick recommendations for you: • Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply) • Attach your dataset if possible (use a fictionalized version if there are privacy concerns) • Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)
Scott
