Text Mining / Clustering / Label Prediction
Hello there,
i am playing arround with some "Text Processing". I've got a collection of about 1000 articles on sport (exspecially soccer/football) news collected from different RSS Feeds.
To start with an good basis I catgorized them all manually into 7 categories. That leads to following distribution (in "german"):
label | count | % |
Teamnews | 430 | 37,01 |
Rest | 166 | 14,29 |
Transfers | 143 | 12,31 |
Skandal | 141 | 12,13 |
Verletzung | 124 | 10,67 |
Management | 99 | 8,52 |
Liganews | 59 | 5,08 |
Summe | 1162 | 100 |
My aim now is to set up a prediction model that will categorize future articels by its own.
That's where i stuck a little bit. Basically i'll do the following text processing:
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.001">
<operator activated="true" class="text:process_document_from_data" compatibility="7.2.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="447" y="136">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
<process expanded="true">
<operator activated="true" class="text:tokenize" compatibility="7.2.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="112" y="34">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="German"/>
<parameter key="max_token_length" value="3"/>
</operator>
<operator activated="true" class="text:filter_by_length" compatibility="7.2.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="246" y="34">
<parameter key="min_chars" value="4"/>
<parameter key="max_chars" value="25"/>
</operator>
<operator activated="true" class="text:transform_cases" compatibility="7.2.000" expanded="true" height="68" name="Transform Cases (3)" width="90" x="380" y="34">
<parameter key="transform_to" value="lower case"/>
</operator>
<operator activated="true" class="text:filter_stopwords_german" compatibility="7.2.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="514" y="34">
<parameter key="stop_word_list" value="Standard"/>
</operator>
<operator activated="true" class="text:filter_stopwords_english" compatibility="7.2.000" expanded="true" height="68" name="Filter Stopwords (3)" width="90" x="648" y="34"/>
<operator activated="true" class="open_file" compatibility="7.2.001" expanded="true" height="68" name="Open File (2)" width="90" x="715" y="136">
<parameter key="resource_type" value="file"/>
<parameter key="filename" value="C:\Master\RSS\stoplist_manuell.txt"/>
</operator>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.2.000" expanded="true" height="82" name="Filter Stopwords (4)" width="90" x="849" y="34">
<parameter key="case_sensitive" value="false"/>
<parameter key="encoding" value="SYSTEM"/>
</operator>
<operator activated="true" class="open_file" compatibility="7.2.001" expanded="true" height="68" name="Open File (3)" width="90" x="916" y="136">
<parameter key="filename" value="C:\Master\RSS\stoplist_manuell_begriffe_aller_kategorien.txt"/>
</operator>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.2.000" expanded="true" height="82" name="Filter Stopwords (5)" width="90" x="1050" y="34">
</operator>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Transform Cases (3)" to_port="document"/>
<connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
<connect from_op="Filter Stopwords (3)" from_port="document" to_op="Filter Stopwords (4)" to_port="document"/>
<connect from_op="Open File (2)" from_port="file" to_op="Filter Stopwords (4)" to_port="file"/>
<connect from_op="Filter Stopwords (4)" from_port="document" to_op="Filter Stopwords (5)" to_port="document"/>
<connect from_op="Open File (3)" from_port="file" to_op="Filter Stopwords (5)" to_port="file"/>
<connect from_op="Filter Stopwords (5)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
</process>
In another process I filtered the labels and checked the created WordLists and was satisfied with the results. So it regnozied the most "important" words for every label.
I stored them in an mysql db. I also created a top50 wordlist wich includes the 50 most used words of a label. But do not use both lists right now.
But back to my current problem. To create a model I choose the X-Validation Operator and tried different classification learners (like: Naive Bayes, k-NN, ID3 and Decision Tree).
Because the results of the performance Operator in all cases where so disappointing, i also used "optimize parameters" operator. Unfortunatelly without positive success.
For example i got an accuracy of 12,48% in my k-NN prediction model.
Here is an example output:
accuracy: 12.48% +/- 0.59% (mikro: 12.48%)
true Skandal | true Management | true Transfers | true Verletzung | true Teamnews | true Rest | true Liganews | class precision | |
pred. Skandal | 141 | 98 | 142 | 124 | 430 | 161 | 58 | 12.22% |
pred. Management | 0 | 0 | 1 | 0 | 0 | 0 | 0 | 0.00% |
pred. Transfers | 0 | 1 | 0 | 0 | 0 | 0 | 0 | 0.00% |
pred. Verletzung | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0.00% |
pred. Teamnews | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0.00% |
pred. Rest | 0 | 0 | 0 | 0 | 0 | 4 | 1 | 80.00% |
pred. Liganews | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 0.00% |
class recall | 100.00% | 0.00% | 0.00% | 0.00% | 0.00% | 2.41% | 0.00% |
Tests with reducing the number of articles in label "Teamnews" to #150 to get an better distribution weren't successfull too.
So is there any hint or tip how i can increase my accuracy to something higher than 70%?
Is it a mistake in previous text processing steps?
Should i use my stored wordlists for each categorie instead of the whole articels?
Or is this the completly wrong way of doing it?
If you need any more information, please let me know.
Thanks.
Best,
David
Hi.
Have you tried a Linear SVM in a Polynominal by Binominal Classification operator?
No. Never used before....
I had a look a the tutorial process. It is used with numerical attributes?!
My input training example set has got following structure:
Role | Name | Type |
label | label | nominal |
text |
nominal |
And the operator combination is not able to work with that?
<operator activated="true" class="split_validation" compatibility="7.2.001" expanded="true" height="124" name="Validation (3)" width="90" x="715" y="34">
<parameter key="create_complete_model" value="false"/>
<parameter key="split" value="relative"/>
<parameter key="split_ratio" value="0.7"/>
<parameter key="training_set_size" value="100"/>
<parameter key="test_set_size" value="-1"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="polynomial_by_binomial_classification" compatibility="7.2.001" expanded="true" height="82" name="Polynomial by Binomial Classification (2)" width="90" x="112" y="30">
<parameter key="classification_strategies" value="exhaustive code (ECOC)"/>
<parameter key="random_code_multiplicator" value="2.0"/>
<operator activated="true" class="support_vector_machine_linear" compatibility="7.2.001" expanded="true" height="82" name="SVM (Linear)" width="90" x="380" y="34">
<parameter key="kernel_cache" value="200"/>
<parameter key="C" value="0.0"/>
<parameter key="convergence_epsilon" value="0.001"/>
<parameter key="max_iterations" value="100000"/>
<parameter key="scale" value="true"/>
<parameter key="L_pos" value="1.0"/>
<parameter key="L_neg" value="1.0"/>
<parameter key="epsilon" value="0.0"/>
<parameter key="epsilon_plus" value="0.0"/>
<parameter key="epsilon_minus" value="0.0"/>
<parameter key="balance_cost" value="false"/>
<parameter key="quadratic_loss_pos" value="false"/>
<parameter key="quadratic_loss_neg" value="false"/>
</operator>
<connect from_port="training set" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
</process>
</operator>
<connect from_port="training" to_op="Polynomial by Binomial Classification (2)" to_port="training set"/>
<connect from_op="Polynomial by Binomial Classification (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (3)" width="90" x="45" y="30">
<parameter key="create_view" value="false"/>
</operator>
<operator activated="true" class="performance_classification" compatibility="7.2.001" expanded="true" height="82" name="Performance (Classification)" width="90" x="180" y="30">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="false"/>
<parameter key="kappa" value="false"/>
<parameter key="weighted_mean_recall" value="false"/>
<parameter key="weighted_mean_precision" value="false"/>
<parameter key="spearman_rho" value="false"/>
<parameter key="kendall_tau" value="false"/>
<parameter key="absolute_error" value="false"/>
<parameter key="relative_error" value="false"/>
<parameter key="relative_error_lenient" value="false"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="false"/>
<parameter key="root_mean_squared_error" value="false"/>
<parameter key="root_relative_squared_error" value="false"/>
<parameter key="squared_error" value="false"/>
<parameter key="correlation" value="false"/>
<parameter key="squared_correlation" value="false"/>
<parameter key="cross-entropy" value="false"/>
<parameter key="margin" value="false"/>
<parameter key="soft_margin_loss" value="false"/>
<parameter key="logistic_loss" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
<list key="class_weights"/>
</operator>
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (Classification)" to_port="labelled data"/>
<connect from_op="Performance (Classification)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
</operator>
</process>
EDIT:
Fixed: The text attribute is Type "text" and not nominal.
Hi,
you are right. It does not work on nominal/text attributes. Butyou usually do not train on the text itself. I cannot load your process (for some unknown reason) but it is using tokenization. So the structure of your data should be
label (nominal, label)
Text (text, special)
count_wordA (numerical, regular)
count_wordB (numerical, regular)
count_wordC (numerical, regular)
count_wordD (numerical, regular)
where count might be the TF-IDF value. That is perfect for a SVM.
Best,
Martin
Hey Martin,
thanks for your quick thoughts.
Running the Linear SVM in a Polynominal by Binominal Classification operator leads me to an accuracy of 63.19% +/- 4.75% (mikro: 63.17%).
Not perfect but even really better as my first results. And i think its acceptable.
Unfortunatelly i had to cut of my input examples to a limit of 150 per label. Otherwise rapidminer chrashes on my computer (i5 Core and 16GB RAM).
So thanks again.
Hey Martin,
try to change pruning settings. How may attributes did you create? If it is like 2k, i can imagine why the SVM crashes..
I tried. But 9/10 times rapidminer runs into a loop situation? The process time counter goes on but nothing happens. I am only succesfull if i handle an very large amount of examples (less than 100). This costs me a lot of accuracy.
My origin database includes 1162 examples and 16 regular attributes.
I filter this to 725 examples and 1 regular attributes. Then I start my text preprocessing.
After this step my example set inlcludes 725 examples and 2 special and 72 regular attributes
Using pruning my wordlist only contains 47 examples for all 6 labels. (What i think is very less?!)
When the process runs into the "Polynominal by Binominal" Operator inlcuding the SVM(linear) rapidminer stucks.
<operator activated="true" class="polynomial_by_binomial_classification" compatibility="7.2.001" expanded="true" height="82" name="Polynominal by Binominal Classification (4)" width="90" x="916" y="34">
<parameter key="classification_strategies" value="1 against 1"/>
<operator activated="true" class="support_vector_machine" compatibility="7.2.001" expanded="true" height="124" name="SVM (4)" width="90" x="313" y="34">
<parameter key="kernel_type" value="neural"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_degree" value="2.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<parameter key="C" value="0.001"/>
<parameter key="calculate_weights" value="true"/>
<parameter key="return_optimization_performance" value="true"/>
<parameter key="estimate_performance" value="false"/>
</operator>
<connect from_port="training set" to_op="SVM (4)" to_port="training set"/>
<connect from_op="SVM (4)" from_port="model" to_port="model"/>
</process>
</operator>
</process>
Some information about my hardware:
Betriebsystemname Microsoft Windows 10 Pro
Version 10.0.14393 Build 14393
Systemtyp x64-basierter PC
Prozessor Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2195 MHz, 2 Kern(e), 4 logische(r) Prozessor(en)
Installierter physischer Speicher (RAM) 16,0 GB
Größe der Auslagerungsdatei 800 MB
My Java Version:
Version 8 Update 111 Build 1.8.0_111-b14
Any idea?
Next step for better results would be to optimize on the setting C of the SVM. Take a logarithmic "grid" between 1e-3 to 1e3. That should boost it.
This is a good hint and i will check it, when the problem situation above is solved.
Best wishes,
David
Hi,
quick thought: Have you tried a Linear SVM in a Polynominal by Binominal Classification operator?
~Martin
