1 - 2 of
21
yes, "Extract Makro" operator will do the job. I will rebuild my process...
Thanks!
Thomas
1 - 1 of
11
Hi @thomas_wiedmann,
Here an example of process (to adapt to your own project) to get the number of rows of an exampleset :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Golf" width="90" x="112" y="120">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
</operator>
<operator activated="true" class="extract_macro" compatibility="8.1.001" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="120">
<parameter key="macro" value="eCount"/>
<list key="additional_macros"/>
</operator>
<operator activated="true" class="provide_macro_as_log_value" compatibility="8.1.001" expanded="true" height="82" name="Provide Macro as Log Value" width="90" x="380" y="120">
<parameter key="macro_name" value="eCount"/>
</operator>
<operator activated="true" class="log" compatibility="8.1.001" expanded="true" height="82" name="Log" width="90" x="514" y="136">
<list key="log">
<parameter key="Direct" value="operator.Extract Macro.value.macro_value"/>
<parameter key="Indirect" value="operator.Provide Macro as Log Value.value.macro_value"/>
</list>
</operator>
<connect from_op="Golf" from_port="output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/>
<connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="90"/>
</process>
</operator>
</process>
Does this solution answer to your need ?
Regards,
Lionel
Regards,
Lionel
