upload greek in mysql database
icsd11159
icsd11159 New Altair Community Member
edited November 2024 in Community Q&A
Hello,
I have a connection with MySQL database and i pass values in a table but i have greek words and in database tha results are like: ??????dbn.PNG
Welcome!
Best Answer
  • icsd11159
    Answer ✓
    Thank you all for your help , i just solve my problem by setting the appropriate connection properties in RapidMiner Studio : via Connections > Manage Database Connections > Advanced and check the
    <SPAN class="str">characterEncoding</SPAN>
    and write utf8 in the blank next to it .
     Also must check and
    <SPAN class="str">useEncoding</SPAN>
Answers
  • sgenzer
    sgenzer
    Altair Employee
    hello @icsd11159 - is that a RapidMiner screenshot? I do not recognize those icons.
    Scott
  • icsd11159
    This is a screenshot from my database , that writes greek perfect from hltm/php but when i use 'write database' operation they turn into ?????.I use 'execute SQL' with 'SET CHARACTER SET UTF8' but nothing is change .Do you have any idea to fix this ?
  • JEdward
    JEdward New Altair Community Member
    Is your RapidMiner display set to Unicode?
  • icsd11159
    My results are in greek , if that's what you asking
  • sgenzer
    sgenzer
    Altair Employee
    ah ok that makes more sense. Most likely that's an encoding issue. Can you check and see if your system RapidMiner encoding is the same as your database? I can see if your system is ISO-8859-1 and your database is UTF-8, you would have a problem.
    Scott
  • JEdward
    Thanks, was just checking by eliminating the first possibility.
    The issue might actually the first one I suspected, the JDBC driver could need an additional connection parameter set as advanced parameters.
    Set useUnicode to yes & characterEncoding to UTF-8
    This should resolve it.
    <SPAN class="pln">jdbc</SPAN><SPAN class="pun">:</SPAN><SPAN class="pln">mysql</SPAN><SPAN class="pun">://</SPAN><SPAN class="pln">localhost</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">3306</SPAN><SPAN class="pun">/</SPAN><SPAN class="pln">db_name</SPAN><SPAN class="pun">?</SPAN><SPAN class="pln">useUnicode</SPAN><SPAN class="pun">=</SPAN><SPAN class="pln">yes</SPAN><SPAN class="pun">&</SPAN><SPAN class="pln">characterEncoding</SPAN><SPAN class="pun">=</SPAN><SPAN class="pln">UTF-8</SPAN>
    See here: https://stackoverflow.com/questions/5090303/how-do-i-get-greek-characters-in-my-database-using-jsp
  • sgenzer
    sgenzer
    Altair Employee
    oh nice catch, @JEdward.
    Scott
  • icsd11159
    Thank you for your reply!
    I agree with you and i think that this must be the solution . But when i change the url path it gives me error dtbe.PNG
    My ManageDatabaseDrivers is like :
  • icsd11159
    Answer ✓
     Also must check and
Welcome!
Welcome!
