*** ERROR # 4800 ***
I am getting below error msg wile solving linear static analysis with temperature in Optistruct. I have even defined TEMPD card also, but error still persist. I have only first order tetrea element in the model. I am unable to do setting mentioned in error msg. Appriciate your help. Thanks !
Grid 22260 connected to element 155913 has no temperature
specified in load set 2. To apply zero temperature on this grid,
SYSSETTING,undeftemp,zero needs to be added to the deck.
Hi Ajay,
A similar error can be found in the community search:
https://community.altair.com/community?id=community_question&sys_id=d2c89a21db476010cfd5f6a4e29619e0&view_source=searchResult
Did you call your TEMPD in your loadcase?
The other option, as mentioned in the ,.out file, is to apply the control card SYSSETTING,UNDEFTEMP,ZERO but it will assign zero temperature to any node that has no temperature.
