Execute Script vs Java Extension coding
OK I think I am just a glutton for punishment but I keep trying to create a simple extension that executes API GET requests. I thought I had it clinched this weekend using the nice "unirest" library. In fact it works perfectly when using the Execute Script operator:
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data_user_specification" compatibility="7.6.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="179" y="187">
<list key="attribute_values"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="execute_script" compatibility="7.6.001" expanded="true" height="82" name="Execute Script" width="90" x="313" y="187">
<parameter key="script" value="import com.mashape.unirest.http.*; import com.mashape.unirest.http.exceptions.UnirestException; import com.rapidminer.tools.Ontology; IOObject inputData = input[0]; Attributes attributes = inputData.getAttributes(); Attribute jsonOutput = AttributeFactory.createAttribute("jsonOutput", Ontology.STRING); attributes.addRegular(jsonOutput); inputData.getExampleTable().addAttribute(jsonOutput); for (Example example : inputData) { 	 	HttpResponse<JsonNode> response = Unirest.get("https://community-bitcointy.p.mashape.com/convert/10/USD") 		.header("X-Mashape-Key", "izQxTY0KZ4mshmrBq7DmXQvlC3hcp16709BjsngW8gm71mH39j") 		.header("X-Mashape-Host", "community-bitcointy.p.mashape.com") 		.asJson(); 	JsonNode foo = response.getBody();	 	String jsonText = foo.toString(); 	example.setValue(jsonOutput, jsonText); } return inputData; "/>
<description align="center" color="transparent" colored="false" width="126">this works</description>
</operator>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Execute Script" to_port="input 1"/>
<connect from_op="Execute Script" from_port="output 1" to_port="result 1"/>
</process>
</operator>
</process>
However when I try to put this in the "extension template", I can never get this to compile:
package com.rapidminer.apitoolbox;
import java.util.logging.Level;
import com.rapidminer.example.Attribute;
import com.rapidminer.example.Attributes;
import com.rapidminer.example.Example;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.example.table.AttributeFactory;
import com.rapidminer.example.utils.ExampleSetBuilder;
import com.rapidminer.example.utils.ExampleSets;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorDescription;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.ports.InputPort;
import com.rapidminer.operator.ports.OutputPort;
import com.rapidminer.operator.ports.metadata.AttributeMetaData;
import com.rapidminer.operator.ports.metadata.ExampleSetMetaData;
import com.rapidminer.operator.ports.metadata.GenerateNewExampleSetMDRule;
import com.rapidminer.operator.ports.metadata.MetaData;
import com.rapidminer.parameter.ParameterType;
import com.rapidminer.parameter.ParameterTypeBoolean;
import com.rapidminer.parameter.ParameterTypeInt;
import com.rapidminer.parameter.UndefinedParameterError;
import com.rapidminer.tools.LogService;
* This operator calls the Bitcointy API (via RapidAPI/Mashape)
* and gets the current USD/BTC exchange rate.
* @author S. Genzer on 1 Oct 2017
public class bitcoin extends Operator {
* @param description
public InputPort exampleSetInput = getInputPorts()
.createPort("exa");
public OutputPort exampleSetOutput = getOutputPorts()
.createPort("exa");
public bitcoin(OperatorDescription description) {
super(description);
@Override
public void doWork() throws OperatorException {
LogService.getRoot().log(Level.INFO, "Doing something...");
ExampleSet exampleSet = exampleSetInput.getData(ExampleSet.class);
Attributes attributes = exampleSet.getAttributes();
exampleSet.getExampleTable().addAttribute(jsonOutput);
for (Example example : exampleSet) {
.header("X-Mashape-Key", "key")
.asJson();
exampleSetOutput.deliver(exampleSet);
Help? This is maddening.
Scott
@mschmitz, a.k.a. "the man with the cape" comes through again. Thank you. I knew it was some conflict with that JsonNode call but could not find it. Yes I had put the compile statement in the dependencies in build.gradle. Not bad for an EE major, right?
Scott
Scott,
i've added the class to a branch of operatortoolbox. A few things:
1. Have you added
compile 'com.mashape.unirest:unirest-java:1.3.1'
to your gradle dependencies?
2.
response = Unirest.get("https://community-bitcointy.p.mashape.com/convert/10/USD") ...
needs a try catch.
3. you added two different implementations of JsonNode. One from mashable the other from
com.fasterxml.jackson.databind.
that screwed it up.
Here the code i was able to compile (but not tested the operator though):
//package com.rapidminer.apitoolbox;
package com.rapidminer.extension.operator.blending;
//import com.fasterxml.jackson.databind.JsonNode;
public class BitCoin extends Operator {
.createPort("exa");
.createPort("exa");
public BitCoin(OperatorDescription description) {
super(description);
@Override
HttpResponse<com.mashape.unirest.http.JsonNode> response = null;
try {
.asJson();
} catch (UnirestException e) {
e.printStackTrace();
Scott,
1. Have you added
2.
needs a try catch.
that screwed it up.
