🎉Community Raffle - Win $25
Join and Win
R extension failed on column selection
User: "wanglu2014"
New Altair Community Member
Updated by Jocelyn
Hi:
My code is
rm_main = function(dat)
    #dat<-dat[-which(rowMeans(is.na(dat)) > 0.5), ]
    dat<-dat[ ,-which(rowMeans(is.na(dat)) > 0.5)]
    return(data.frame(dat))
When run "dat<-dat[-which(rowMeans(is.na(dat)) > 0.5), ]", rapidminer get the wanted dataframe, however, when run "dat<-dat[ ,-which(rowMeans(is.na(dat)) > 0.5)]" is wrong.
It take "which(rowMeans(is.na(dat)) > 0.5)" result as a list, not filter the dataframe.
Could you kindly suggest some idea?
1 - 1 of 11
    User: "SGolbert"
    The error lies in the R code itself. You are subsetting the columns using row data (porcentange of missing values in a row). That is incorrect.
