"Association and Clustering"
User: "AleckN"
New Altair Community Member
Updated by Jocelyn
Regards to the respected community of rapidminer.
I ran into a problem while running an association and clustering analysis. I attached a screenshot of the model as well as the error message. I want to say that I was able to run clustering and association analysis independently, but wasn't able to run them together. I did activate the debug mod as the system suggested, but nothing happened.
Therefore, I thought that I report this problem for feedback or improvement.
Respectfully,
1 - 3 of 31
    User: "Thomas_Ott"
    This thread will be moved to the RapidMiner Studio forum.
    User: "Thomas_Ott"
    Accepted Answer
    If reading in from an XLS, I would not use the Data to Documents and Process Documents operator. I would skip those two and just use a Nominal to Text operator and Process Documents from Data operator instead.
    User: "AleckN"
    OP
    Thank you very much. It worked!
    This is very beneficial.
    Best Regards,
