Creating an operator Changing Configurations
I want to create a new class for that I have made all the changes given in these links
http://docs.rapidminer.com/developers/creating-your-own-extension/your-own-operator/
I changed the code in OperatorTempelate.xml, OperatorDocTempelate.xml, groupsTempelate.properties and insert icons
and then I installed the extension and it gives me no error
when I checked it in rapid miner no such operator has been created
Can anyone guide me where i went wrong
Hi,
would you mind sharing what your problem was?
There is little more infuriating than searching on the internet for a problem, only to find a post by someone who had the same problem and then later just wrote "fixed it myself" because that essentially amounts to "but I'm not telling you how, haha!" :smileyhappy:
Regards,
Marco
its done
