To workaround the issue that ‘write Excel’ cannot append extra data frame to another sheet of an existing excel file. We can combine R scripts inside Rapidminer Studio to write multiple sheets with the xlsx package from R.
You just need to use a different sheetName for each data frame and you need to add append=TRUE, and this is the example code put inside 'Excetue R' operator
# rm_main is a mandatory function,
# the number of arguments has to be the number of input ports (can be none)
rm_main = function(data)
#install.packages("xlsx")
dataframe2 <- data
library(xlsx)
write.xlsx(data, file="C:\\Users\\YuanyuanHuang\\Documents\\RMCommunity\\filename.xlsx", sheetName="sheet1")
write.xlsx(dataframe2, file="C:\\Users\\YuanyuanHuang\\Documents\\RMCommunity\\filename.xlsx", sheetName="sheet2", append=TRUE)
return(list(data))
Here are a couple links to help you manipulate your excel logic...
(Terms to be aware of….Column = attribute, Row = Example, Function = Operator)
An alternative would be to store all the texts as single entries in a repository first, then loop and add it to a csv file using the 'append to file'. This way your examples are added file by file instead of all at once and you don't reach the example limit. You can than open the csv in excell and save it as xslx.
But of course having a licensed version would be the more flexibe option...
No, that functionality is not available.
