🎉Community Raffle - Win $25
Join and Win
Installing extensions (Windows )
manisha1595User: "manisha1595"
New Altair Community Member
Updated by Jocelyn
Hey,
     I have my rapidminer_server folder in windows machine on path "D:\Rapidminner_server" and created a folder plugins ("D:\Rapidminner_server\plugins") to store extensions. In Rapidminer server "com.rapidanalytics.plugindir" is empty so i set path as above but it is still not loading extension to the server.
Any help will be appriciated Smiley Happy
1 - 12 of 121
     Did you shutdown and restart the server?
    yes...i followed every step of how to install extension on rapidminer server article.
    I just noticed that you spelled "rapidminner"
    Is your path correct?
    Another remark: I consider it better to keep the plugins and other folders outside of the RM Server installation folder. This makes updates easier.
    E.g.:
    d:\RapidMiner
    + server
    + logs
    + plugins
    + uploads
    Regards,
    Balázs
    yes it is correct path....
    In command prompt while running rapidminer server it is showing following error:
    Cannot load extension rmx_com.solr:Depends on rmx_test which cannot be found!
    E.g.:
    d:\RapidMiner
    + server
    + logs
    + plugins
    + uploads
    Regards,
    Balázs
    Thanks for the advice :)
    I created separate folder...still it is not loading the extensions.
    mmichelUser: "mmichel"
    Is it possible that you provide the server log file? If you don't want to attach it to this thread you can also send me a PM.
    Cheers,
    Marcel
    Edin_KlapicUser: "Edin_Klapic"
    Accepted Answer
    Hi manisha 1595,
    the Solr extension has dependency to the Text extension which explains the following error:
    Cannot load extension rmx_com.solrSmiley Very Happyepends on rmx_test which cannot be found!
    A solution is to copy the Text extension file rmx_text into the plugin folder and restart the server.
    Best regards,
    Edin
    @Edin_Klapic wrote:
    Hi manisha 1595,
    Best regards,
    Edin
    Thank you so much.....the solution worked....the extensions are loaded successfully ....finally I can work on my project :)
    Thank you everyone for your valuable time to solve my problem :)
    Good luck on your project!
    Hello ,
    i face the same problem , but i don't understand the solution you had! I create a folder outside of server , i copy the rmx_text jar file and i write the path to service settings , re-start the server but the extension doesn't install .
    What am i doing wrong?
