statistics in Extract Macro
hmhsing
hmhsing Altair Community Member
edited November 2024 in Community Q&A
I have a problem while doing the challenge in Rapidminer tutorial "Looping, Branching and Appending." I use min in statistics in Extract Macro to get minimum sample size (which is 277), the problem occured.  It shows: The value '277.0' for the parameter 'condition_value' cannot be used: java.lang.NumberFormatException: for input string: "277.0". The specified value is not possible for this parameter. Please set a proper parameter value.      Can anyone help me with this?  Thanks!
Welcome!
Best Answer
  • hmhsing
    Answer ✓
    It worked when I add Generate Macro operator with round(eval(%{macro name defined in Extract Macro})) in functions expressions.
Answers
  • singh_ay
    singh_ay New Altair Community Member
    Facing exactly same issue, I even tried the GENERATE MACRO OPERTOR to "eval" but of no use.
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    Would you please share the XML, I can take a look at it.
  • hmhsing
    Answer ✓
  • Thomas_Ott
    Awesome! great to hear!
Welcome!
Welcome!
