1 - 3 of
31
@mschmitz wrote:Hey,
please have a look at the tutorial process of FP-Growth. It's done there. Should be Pivot + Numerical to Binominal.
I recommend Beta mode for this.
~Martin
I tried that but no ideal answer! can you give me more detail, pls
Hey,
attached is a process solving it.
~Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="82" name="Subprocess" width="90" x="45" y="34">
<operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="45" y="34">
<list key="attribute_values">
<parameter key="Tid" value="1"/>
<parameter key="id" value="1"/>
</list>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="45" y="136">
<parameter key="id" value="2"/>
</list>
</operator>
<operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="45" y="238">
<parameter key="Tid" value="2"/>
</list>
</operator>
<operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (4)" width="90" x="45" y="340">
<parameter key="id" value="3"/>
</list>
</operator>
<operator activated="true" class="append" compatibility="7.4.000" expanded="true" height="145" name="Append" width="90" x="246" y="136"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 4"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 3"/>
<connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 2"/>
<connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_port="out 1"/>
<portSpacing port="source_in 1" spacing="0"/>
<portSpacing port="sink_out 1" spacing="0"/>
<portSpacing port="sink_out 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="generate_attributes" compatibility="7.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
<list key="function_descriptions">
<parameter key="value" value="1"/>
</list>
<description align="center" color="transparent" colored="false" width="126">Create a constant for pivot</description>
</operator>
<operator activated="true" class="pivot" compatibility="7.4.000" expanded="true" height="82" name="Pivot" width="90" x="313" y="34">
<parameter key="group_attribute" value="Tid"/>
<parameter key="index_attribute" value="id"/>
<parameter key="skip_constant_attributes" value="false"/>
</operator>
<operator activated="true" class="replace_missing_values" compatibility="7.4.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="447" y="34">
<parameter key="default" value="zero"/>
<list key="columns"/>
</operator>
<operator activated="true" class="numerical_to_binominal" compatibility="7.4.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="581" y="34"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/>
<connect from_op="Pivot" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
1 - 1 of
11
Hey,
~Martin
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</operator>
</list>
</operator>
</list>
</operator>
</list>
</operator>
</process>
</operator>
</list>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
Hey,
~Martin
