Hi
I want to convert my database to item set form. For example assume table:
Tid Item
1 1
1 2
2 1
2 3
I want it changes to:
Tid Item1 Item2 Item3
1 true true false
2 true false true
How can I do that in rapidminer studio?
Hey,
attached is a process solving it.
~Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="7.4.000" expanded="true" height="82" name="Subprocess" width="90" x="45" y="34"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="45" y="34"> <list key="attribute_values"> <parameter key="Tid" value="1"/> <parameter key="id" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="45" y="136"> <list key="attribute_values"> <parameter key="Tid" value="1"/> <parameter key="id" value="2"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="45" y="238"> <list key="attribute_values"> <parameter key="Tid" value="2"/> <parameter key="id" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="7.4.000" expanded="true" height="68" name="Generate Data by User Specification (4)" width="90" x="45" y="340"> <list key="attribute_values"> <parameter key="Tid" value="2"/> <parameter key="id" value="3"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="7.4.000" expanded="true" height="145" name="Append" width="90" x="246" y="136"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_attributes" compatibility="7.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="value" value="1"/> </list> <description align="center" color="transparent" colored="false" width="126">Create a constant for pivot</description> </operator> <operator activated="true" class="pivot" compatibility="7.4.000" expanded="true" height="82" name="Pivot" width="90" x="313" y="34"> <parameter key="group_attribute" value="Tid"/> <parameter key="index_attribute" value="id"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="7.4.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="447" y="34"> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="7.4.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="581" y="34"/> <connect from_op="Subprocess" from_port="out 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
please have a look at the tutorial process of FP-Growth. It's done there. Should be Pivot + Numerical to Binominal.
I recommend Beta mode for this.
@mschmitz wrote: Hey, please have a look at the tutorial process of FP-Growth. It's done there. Should be Pivot + Numerical to Binominal. I recommend Beta mode for this. ~Martin
I tried that but no ideal answer! can you give me more detail, pls
