questions on importing EXCEL files whose columns are of mixed formats
1 - 3 of
31
As Marius suggested originally, the best solution is to set the data type to polynominal during the Excel import, which will then allow both numeric and non-numeric characters and all the data will be imported. Once all the data is in RapidMiner, you can then convert the numerical data using "Parse Numbers" and also decide how you want to deal with the non-numerics (simply have missing values, impute missing values, etc.).
RapidMiner can only handle columns with a consistent data type. So in your case you have to define all columns as polynominal to make sure that the Read Excel operator can correctly read the complete file. Then you can process the file further in RapidMiner. If there is a condition that determines the type of a row you could use Filter Examples to split the data set into a part that contains the text values and another that contains the numbers. Then use Parse Numbers on the number part to convert polynominal to numbers.
Please note that Parse Numbers will silently fail if there is a value in the column that cannot be converted to a number.
Best regards,
Marius
