k-means clustering how to indicate what attributes will be used?
caryknoop
caryknoop New Altair Community Member
edited November 2024 in Community Q&A
How do you indicate what columns to use for k-means clustering.
Assume you have the following attributes:  BadlyDistributedID,  IdentifyingName, Col1, Col2, Col3.
Only Col1, Col2 and Col3 should be considered, how to do this?
Welcome!
Answers
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi caryknoop,
    for all learning task, all regular attributes will be used. Simply set the role of your Name and ID to something using Set Role. You can type anything except regular there. Roles need to be unique.
    ~Martin
  • Telcontar120
    Telcontar120 New Altair Community Member
    You can also use a "select attributes" operator if you want to limit clustering to only a subset of the regular attributes in the file, just place it immediately before your clustering operator.
  • andreas_camenzi
    andreas_camenzi New Altair Community Member
    Hi Martin
    Thank you for your help.
    Do you also know a solution if the attributes are more than 7. We want to display a chart with 2 attributes but need the information of around 10 additional attributes.
    It is only possible to assign 1 additional attribute per role.
    Thanks & best regards
    Andreas
    If we just want to include
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    you can simply type anything you want instead of "label","id" etc. just type att1, att2, att3 for the desired role.
     ~Martin
Welcome!
Welcome!
