RapidMiner extension (jar) and MAC
Hello All,
I have developed an extension for RapidMiner in windows, have tested and verified results also. Now I have switched to MAC, and I can't figure out where to put the jar file exactly.
Is this path correct? user/.RapidMiner/managed/my_extension.jar
What else needs to be done to make that extension workable on mac's RapidMiner?
Thanks for your help
1 - 1 of
11
Hi,
The managed folder is for extensions installed form the Marketplace and you should not manually edit that.
Please create the ~/.RapidMiner/extensions folder and place your jar in there. You can modify this default path by editing your RapidMiner Studio settings in the Start-up tab.
Best, Zoltan
