compressible flow with acusolve
Hi, I am working on a case, where a pressure wave hits a structure. I only have a measured pressure profile of the static pressure, the maximum is at about 1bar overpressure.
At first I only want to simulate this pressure wave in an simple rectangular pipe. I am struggeling a bit to find the right bc's and model settings. Is there any documentation with general advice and guidelines for compressible flow with acusolve? (I already found ACU-T: 2400)
