NoSQL Mongo extension causing java.lang.NullPointerException
User: "ozzy"
New Altair Community Member
Updated by Jocelyn
Hi,
I have RM 2.4 server problem. I copied NoSQL (rmx_nosql-6.4.0) and text mining (rmx_text-6.4.1) extensions from RM Studio into server plugins directory. They load fine, I configured Mongo connection and it tests OK in config window. The server is trial version, running with Java jre-7u79 64bit on Windows7.
When I run a process with Mongo read it fails like this:
May 30, 2015 8:53:16 PM <unknown> <unknown>
INFO: Process context is: Macros: [_ra_user : admin, _ra_jobID : 28]; Input: []; Output: []
INFO: No filename given for result file, using stdout for logging results!
INFO: Process //_LOCAL/home/admin/test2mongo starts
SEVERE: Process failed: java.lang.NullPointerException
SEVERE: Here:          Process[1] (Process)
          subprocess 'Main Process'
      ==>  +- Read MongoDB[1] (Read MongoDB)
            +- JSON To Data[0] (JSON To Data)
Same process executes OK on RM Studio.
Anyone have any ideas about this issue?
Ozzy
1 - 13 of 131
    User: "Marco_Boeck"
    Hi,
    can you please post the entire server.log? I just tried it and it works fine for me.
    Regards,
    Marco
    User: "ozzy"
    OP
    Hi, sure here is the complete log:
    12:15:15,698 SEVERE [com.rapidminer.Process.1] (QuartzScheduler_Worker-3) Process failed: java.lang.NullPointerException: java.lang.NullPointerException
    at com.rapidminer.tools.config.ServerConfigurationManager.checkAccess(ServerConfigurationManager.java:70) [rapidminer-server-ejb.jar:]
    at com.rapidminer.tools.config.ConfigurationManager.lookup(ConfigurationManager.java:325) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.operator.mongodb.MongoDBConnector.doWork(MongoDBConnector.java:96)
    at com.rapidminer.operator.Operator.execute(Operator.java:974) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:35) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:779) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:377) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.Process.run(Process.java:1037) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.Process.run(Process.java:939) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.Process.run(Process.java:892) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at com.rapidminer.Process.run(Process.java:887) [rapidminer-studio-core-6.4.0.jar:6.4.0]
    at de.rapidanalytics.execution.AbstractProcessExecutor.runProcessNow(AbstractProcessExecutor.java:95) [rapidminer-server-ejb.jar:]
    at de.rapidanalytics.execution.SimpleProcessExecutor.execute(SimpleProcessExecutor.java:31) [rapidminer-server-ejb.jar:]
    at de.rapidanalytics.execution.ProcessExecutionDispatcher.dispatch(ProcessExecutionDispatcher.java:142) [rapidminer-server-ejb.jar:]
    at de.rapidanalytics.ejb.ProcessJobEJBImpl.executeJob(ProcessJobEJBImpl.java:182) [rapidminer-server-ejb.jar:]
    at de.rapidanalytics.ejb.ProcessJobEJBImpl.executeJob(ProcessJobEJBImpl.java:103) [rapidminer-server-ejb.jar:]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [rt.jar:1.7.0_79]
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) [rt.jar:1.7.0_79]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) [rt.jar:1.7.0_79]
    at java.lang.reflect.Method.invoke(Unknown Source) [rt.jar:1.7.0_79]
    at org.jboss.as.ee.component.ManagedReferenceMethodInterceptorFactory$ManagedReferenceMethodInterceptor.processInvocation(ManagedReferenceMethodInterceptorFactory.java:72) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:288) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.invocation.WeavedInterceptor.processInvocation(WeavedInterceptor.java:53) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.as.ee.component.interceptors.UserInterceptorFactory$1.processInvocation(UserInterceptorFactory.java:58) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.invocationmetrics.ExecutionTimeInterceptor.processInvocation(ExecutionTimeInterceptor.java:43) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.jpa.interceptor.SBInvocationInterceptor.processInvocation(SBInvocationInterceptor.java:47) [jboss-as-jpa-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.tx.EjbBMTInterceptor.handleInvocation(EjbBMTInterceptor.java:104) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.tx.BMTInterceptor.processInvocation(BMTInterceptor.java:56) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.invocation.InitialInterceptor.processInvocation(InitialInterceptor.java:21) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:61) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.as.ee.component.interceptors.ComponentDispatcherInterceptor.processInvocation(ComponentDispatcherInterceptor.java:53) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.pool.PooledInstanceInterceptor.processInvocation(PooledInstanceInterceptor.java:51) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.remote.EJBRemoteTransactionPropagatingInterceptor.processInvocation(EJBRemoteTransactionPropagatingInterceptor.java:79) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.interceptors.ShutDownInterceptorFactory$1.processInvocation(ShutDownInterceptorFactory.java:64) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:59) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:54) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ee.component.TCCLInterceptor.processInvocation(TCCLInterceptor.java:45) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:165) [jboss-as-ee-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.ejb3.remote.LocalEjbReceiver.processInvocation(LocalEjbReceiver.java:222) [jboss-as-ejb3-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.ejb.client.EJBClientInvocationContext.sendRequest(EJBClientInvocationContext.java:181) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.EJBHomeCreateInterceptor.handleInvocation(EJBHomeCreateInterceptor.java:79) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.EJBClientInvocationContext.sendRequest(EJBClientInvocationContext.java:183) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.TransactionInterceptor.handleInvocation(TransactionInterceptor.java:42) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.ReceiverInterceptor.handleInvocation(ReceiverInterceptor.java:125) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.EJBInvocationHandler.doInvoke(EJBInvocationHandler.java:177) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.EJBInvocationHandler.doInvoke(EJBInvocationHandler.java:161) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at org.jboss.ejb.client.EJBInvocationHandler.invoke(EJBInvocationHandler.java:124) [jboss-ejb-client-1.0.16.Final.jar:1.0.16.Final]
    at com.sun.proxy.$Proxy49.executeJob(Unknown Source)
    at de.rapidanalytics.web.tools.ProcessExecutionJob.execute(ProcessExecutionJob.java:50)
    at org.quartz.core.JobRunShell.run(JobRunShell.java:223) [quartz-1.8.6.jar:]
    at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:549) [quartz-1.8.6.jar:]
    12:15:15,722 SEVERE [com.rapidminer.Process.1] (QuartzScheduler_Worker-3) Here:          Process[1] (Process)
    12:15:15,727 INFO  [de.rapidanalytics.execution.LogRecordCollector] (QuartzScheduler_Worker-3) Saving records now
    12:15:15,961 INFO  [de.rapidanalytics.execution.LogRecordCollector] (QuartzScheduler_Worker-3) Completed saving records
    12:15:15,961 INFO  [de.rapidanalytics.ejb.ProcessJobEJBImpl] (QuartzScheduler_Worker-3) Completed execution of process /home/admin/test2mongo
    12:15:15,962 INFO  [de.rapidanalytics.ejb.ProcessJobEJBImpl] (QuartzScheduler_Worker-3) Marking process as completed with exception java.lang.NullPointerException
    12:15:16,026 INFO  [de.rapidanalytics.ejb.SchedulerEJBImpl] (QuartzScheduler_Worker-3) Marking process execution parameters /home/admin/test2mongo, id 35 as completed.
    User: "Marco_Boeck"
    Hi,
    that helps, however we still need the complete server.log, from the point onwards you executed the process. The setup behind the scenes before the actual process execution is the most interesting part for us ;)
    Regards,
    Marco
    User: "ozzy"
    OP
    Sure no problem, here is a fresh server startup followed by process execution from the web interface.
    After that I connected rapidminer studio and when I connect to RM server repository bunch of socket write errors start to pop up. This is another problem that makes it impossible to work with the server over the VPN connection.I figured that this might be related to my original problem so you will see these errors after the mongo error.
    Log file is to big for a post so here is dropbox link:
    https://www.dropbox.com/s/nvey3tviawqd0fu/server.log?dl=0
    Thanks
    Ozzy
    User: "Marco_Boeck"
    Hi,
    Are you executing the process as admin? How exactly did you start it? Via Studio or via Server interface? Because the log states it does not know the user and thus falls back to a null user. The NullPointerException is a bug on our side regardless (I have filed a ticket for that), but the process should not be executed as a null user..
    On another note, do you experience any problems regarding the socket write errors, or is it purely in the logs? From my experience, those socket write errors can be safely ignored.
    Regards,
    Marco
    User: "ozzy"
    OP
    Hi,
    yes I was executing the process as admin. I tried running it from the Studio and via the server web interface.. with the same results.
    I'll try with another user account and see if this helps.
    Regarding socket write errors, when I run Studio locally, there are occasional freeze-ups when communicating with the server and once in a while server status will go offline. If I try to connect via remote VPN connection, server is unusable due to excruciating pauses almost every time you try to access it from the studio. .
    Ozzy
    User: "ozzy"
    OP
    Ok, tried executing process from the server interface as another user, after I set process  permissions, same result...
    Is this a matter of using the same  usernames in windows and RM ? Is there a quick workaround you can think of so I can get going until bug fix gets done?
    Ozzy
    User: "Marco_Boeck"
    Hi,
    no, this is weird. Can you try explicitly setting all permissions on the MongoDB connection in the Server UI?
    Regards,
    Marco
    User: "ozzy"
    OP
    Did that, tried executing from the console as admin and some other user... still the same.
    I am starting to think that maybe we have some wired interplay of different versions of OS, Java and Mongo extensions...
    I am thinking of doing a totally fresh install on a brand new server..
    What is the proven version of Java jre for windows install I should use?
    Ozzy
    User: "Marco_Boeck"
    Hi,
    if anything, it is a problem stemming from something in the database backing the server.
    Latest Java 7 is recommended. Won't work with Java 8 at the moment.
    Regards,
    Marco
    User: "ozzy"
    OP
    Ok, the plot thickens...
    I did a fresh W2012 server install, loaded fresh mySQL, Java 7 jre, installed Rapidminer server and loaded Mongo extensions.
    Now I get java null pointer exception when I test the server connection during the configuration. So, worse than before....
    Any ideas where do we go from here....?
    Ozzy
    00:02:45,798 INFO  [de.rapidanalytics.web.beans.ConfigurableEditorBean] (http-/0.0.0.0:8080-3) Executing configurable test.
    00:02:45,985 WARNING [com.rapidminer] (http-/0.0.0.0:8080-3) Failed to connect to MongoDB.: java.lang.NullPointerException
    at java.util.concurrent.ConcurrentHashMap.hash(ConcurrentHashMap.java:333) [rt.jar:1.7.0_80]
    at java.util.concurrent.ConcurrentHashMap.get(ConcurrentHashMap.java:988) [rt.jar:1.7.0_80]
    at com.mongodb.Mongo.getDB(Mongo.java:340)
    at com.rapidminer.configurable.mongodb.MongoDBConfigurable.getConnection(MongoDBConfigurable.java:100)
    at com.rapidminer.configurable.mongodb.MongoDBConfigurable$1.doWork(MongoDBConfigurable.java:127)
    at de.rapidanalytics.web.beans.ConfigurableEditorBean.test(ConfigurableEditorBean.java:323) [classes:]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [rt.jar:1.7.0_80]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) [rt.jar:1.7.0_80]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [rt.jar:1.7.0_80]
    at java.lang.reflect.Method.invoke(Method.java:606) [rt.jar:1.7.0_80]
    at org.apache.el.parser.AstValue.invoke(AstValue.java:258) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:278) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at javax.faces.event.MethodExpressionActionListener.processAction(MethodExpressionActionListener.java:153) [jboss-jsf-api_2.1_spec-2.1.18.Final.jar:2.1.18.Final]
    at javax.faces.event.ActionEvent.processListener(ActionEvent.java:88) [jboss-jsf-api_2.1_spec-2.1.18.Final.jar:2.1.18.Final]
    at javax.faces.component.UIComponentBase.broadcast(UIComponentBase.java:775) [jboss-jsf-api_2.1_spec-2.1.18.Final.jar:2.1.18.Final]
    at javax.faces.component.UICommand.broadcast(UICommand.java:300) [jboss-jsf-api_2.1_spec-2.1.18.Final.jar:2.1.18.Final]
    at org.ajax4jsf.component.AjaxActionComponent.broadcast(AjaxActionComponent.java:55) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.component.AjaxViewRoot.processEvents(AjaxViewRoot.java:329) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.component.AjaxViewRoot.broadcastEventsForPhase(AjaxViewRoot.java:304) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.component.AjaxViewRoot.processPhase(AjaxViewRoot.java:261) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.component.AjaxViewRoot.processApplication(AjaxViewRoot.java:474) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81) [jsf-impl-2.1.18-jbossorg-1.jar:]
    at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101) [jsf-impl-2.1.18-jbossorg-1.jar:]
    at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118) [jsf-impl-2.1.18-jbossorg-1.jar:]
    at javax.faces.webapp.FacesServlet.service(FacesServlet.java:593) [jboss-jsf-api_2.1_spec-2.1.18.Final.jar:2.1.18.Final]
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:295) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:214) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:206) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:388) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:515) [richfaces-impl-jsf2-3.3.3.Final.jar:3.3.3.Final]
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:246) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at de.rapidanalytics.web.filter.SetupFilter.doFilter(SetupFilter.java:94) [classes:]
    at de.rapidanalytics.web.filter.IE8CompatibilityFilter.doFilter(IE8CompatibilityFilter.java:40) [classes:]
    at de.rapidanalytics.web.filter.AccessLogFilter.doFilter(AccessLogFilter.java:50) [classes:]
    at de.rapidanalytics.web.filter.ConstraintViolationFilter.doFilter(ConstraintViolationFilter.java:44) [classes:]
    at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:154) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:110) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:50) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-3.2.8.RELEASE.jar:3.2.8.RELEASE]
    at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160) [spring-security-web-3.2.4.RELEASE.jar:3.2.4.RELEASE]
    at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343) [spring-web-3.2.8.RELEASE.jar:3.2.8.RELEASE]
    at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260) [spring-web-3.2.8.RELEASE.jar:3.2.8.RELEASE]
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:149) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.jboss.as.jpa.interceptor.WebNonTxEmCloserValve.invoke(WebNonTxEmCloserValve.java:50) [jboss-as-jpa-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.jboss.as.web.security.SecurityContextAssociationValve.invoke(SecurityContextAssociationValve.java:169) [jboss-as-web-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:145) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:97) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:102) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:336) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:653) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:920) [jbossweb-7.2.0.Final.jar:7.2.0.Final]
    at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_80]
    00:02:46,141 WARN  [org.ajax4jsf.context.AjaxContext] (http-/0.0.0.0:8080-3) Target component for id actions not found
    User: "ozzy"
    OP
    Hi,
    after a long night and some sleep, fresh start in the morning... coffee and ... solution !
    Back to original install, it all seems to be related to anonymous user account in RM server. I created anonymous and anonymousUser accounts and this got the whole thing going. I'll do some more tests and report further details if any...
    Thanks,
    Ozzy
    User: "Marco_Boeck"
    Hi,
    I'm afraid that's a quirk when creating a new connection via the Server UI. You need to click "Submit" before testing because of the way it works behind the scenes. Otherwise the data you enter is not set and you're basically testing whether an all empty connection works.
    What I would suggest is actually using Studio to create and edit Server connections via "Tools"-> "Manage Connections". You can select your Server on the left side and then test and store connections via the GUI.
    Regards,
    Marco
