NoSQL Mongo extension causing java.lang.NullPointerException
Hi,
I have RM 2.4 server problem. I copied NoSQL (rmx_nosql-6.4.0) and text mining (rmx_text-6.4.1) extensions from RM Studio into server plugins directory. They load fine, I configured Mongo connection and it tests OK in config window. The server is trial version, running with Java jre-7u79 64bit on Windows7.
When I run a process with Mongo read it fails like this:
Anyone have any ideas about this issue?
Ozzy
May 30, 2015 8:53:16 PM <unknown> <unknown>Same process executes OK on RM Studio.
INFO: Process context is: Macros: [_ra_user : admin, _ra_jobID : 28]; Input: []; Output: []
INFO: No filename given for result file, using stdout for logging results!
INFO: Process //_LOCAL/home/admin/test2mongo starts
SEVERE: Process failed: java.lang.NullPointerException
SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
==> +- Read MongoDB[1] (Read MongoDB)
+- JSON To Data[0] (JSON To Data)
Ozzy
