Altair RISE
Nominate Yourself Now!
Append multiple 1 row datasets together
User: "mob"
New Altair Community Member
Updated by Jocelyn
if I have a folder of 1 row datasets with the same attribute count and type how do I append them into 1 larger dataset? The append operator obviously looks for 2 inputs but is it smart enough to know that the 2nd dataset might be coming from a loop operator?
1 - 8 of 81
    User: "sgenzer"
    Altair Employee
    you can connect as many inputs to the append operator as you like.  It just expands.  Just make sure that there are exactly the same number of attributes in each one and they are the same type.
    Scott
    User: "mob"
    OP
    I'm more trying to connect a loop example sets output to 1 of the append inputs, have no other inputs on the append operator and end up with 1 large example set (row count) instead of multiple datasets each with 1 row.
    User: "sgenzer"
    Altair Employee
    Ah I understand.  Some loop operators (like Loop Examples) do NOT actually filter out - they pass the entire example set through and just create an "example" macro to use in the loop.  Other loop operators (like Loop Values) DO filter and only pass the filtered example set through.  Then you need to append back together again.
    Loop Examples with Iris sample data set
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.4.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          </operator>
          <operator activated="true" class="loop_examples" compatibility="6.4.000" expanded="true" height="76" name="Loop Examples" width="90" x="246" y="120">
              <portSpacing port="source_example set" spacing="0"/>
              <portSpacing port="sink_example set" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Examples" to_port="example set"/>
          <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Loop Values with Iris sample data set
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          </operator>
          <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="246" y="120">
            <parameter key="attribute" value="label"/>
              <connect from_port="example set" to_port="out 1"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="380" y="120"/>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Values" to_port="example set"/>
          <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/>
          <connect from_op="Append" from_port="merged set" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Make sense?
    Scott
    User: "mob"
    OP
    Its more a pre-processing step to create a new dataset from multiple smaller ones which all have the same
    If you look at this simple setup the append operator is fine if I have a small number of datasets  (x = 5) I can wire up individually but if x = 100 or 1000 then it becomes alot of work and very messy. Is there a way in rapidminer to accomplish this using ? Collections would just group them together but I need to end up with 1 dataset and forget about the individual datasets from then on.
    Is it a case of needing to start a different way so i don't end up with 1000's of small datasets in the first place
    <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
          <operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Data x = 1" width="90" x="112" y="120"/>
          <operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Data X = n" width="90" x="112" y="255"/>
          <operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="94" name="Append" width="90" x="313" y="165"/>
          <operator activated="true" class="store" compatibility="5.3.015" expanded="true" height="60" name="Store" width="90" x="447" y="165"/>
          <connect from_op="Data x = 1" from_port="output" to_op="Append" to_port="example set 1"/>
          <connect from_op="Data X = n" from_port="output" to_op="Append" to_port="example set 2"/>
          <connect from_op="Append" from_port="merged set" to_op="Store" to_port="input"/>
        </process>
      </operator>
    </process>
    User: "JEdward"
    Actually what Scott might not have noticed is that the Loop Examples operator has two output ports.
    One is Exa which is the last iteration of your process if connected (or the last iteration of the loop depending on how you connect it).
    The other port name out is the one you want to connect to as it outputs a collection of all the loops in your set.
    Here's Scott's Iris & Loop Examples example again reworked to show two ways of getting Output from the loop operator.
    The 3rd way is using Remember & Recall if your operator doesn't have an output port.
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          </operator>
          <operator activated="true" breakpoints="after" class="loop_examples" compatibility="6.4.000" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="120">
              <connect from_port="example set" to_port="output 1"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="447" y="165"/>
          <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/>
          <connect from_op="Append" from_port="merged set" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    Hi,
    if you already have all your datasets in a repository folder, you can just loop over it and append the collection.
    <process version="6.5.000">
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
     <operator activated="true" class="process" compatibility="6.5.000" expanded="true" name="Process">
         <operator activated="true" class="loop_repository" compatibility="6.5.000" expanded="true" height="76" name="Loop Repository" width="90" x="45" y="30">
           <parameter key="repository_folder" value="//Local Repository/LoopTest/"/>
           <parameter key="entry_type" value="IOObject"/>
             <connect from_port="repository object" to_port="out 1"/>
             <portSpacing port="source_repository object" spacing="0"/>
             <portSpacing port="source_in 1" spacing="0"/>
           </process>
           <description align="center" color="transparent" colored="false" width="126">Select the desired repository folder (and optional filters)</description>
         </operator>
         <operator activated="true" class="append" compatibility="6.5.000" expanded="true" height="76" name="Append" width="90" x="179" y="30">
           <description align="center" color="transparent" colored="false" width="126">Appends all ExampleSets of the input collection</description>
         </operator>
         <connect from_op="Loop Repository" from_port="out 1" to_op="Append" to_port="example set 1"/>
       </process>
     </operator>
    </process>
    Regards,
    Marco
    User: "JEdward"
    & here's a more complicated example in case you find any datasets that are missing attributes (or have additional ones)
    By using Remember, Recall operators you can combine the examplesets together (in this case using Union rather than Append).
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
          <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data x = 1" width="90" x="45" y="75"/>
          <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember" width="90" x="179" y="165">
            <parameter key="name" value="mycollection"/>
            <description align="center" color="transparent" colored="false" width="126">This happens first to initialise the remember</description>
          </operator>
          <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n" width="90" x="45" y="345"/>
          <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (2)" width="90" x="45" y="435">
            <parameter key="number_of_attributes" value="3"/>
          </operator>
          <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (3)" width="90" x="45" y="525">
            <parameter key="number_of_attributes" value="8"/>
          </operator>
          <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (4)" width="90" x="45" y="615">
            <parameter key="number_of_attributes" value="10"/>
          </operator>
          <operator activated="true" class="collect" compatibility="6.4.000" expanded="true" height="130" name="Collect" width="90" x="179" y="480"/>
          <operator activated="true" class="loop_collection" compatibility="6.4.000" expanded="true" height="76" name="Loop Collection" width="90" x="380" y="435">
              <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall" width="90" x="112" y="30">
              </operator>
              <operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="112" y="390"/>
              <operator activated="true" class="union" compatibility="6.4.000" expanded="true" height="76" name="Union" width="90" x="179" y="165"/>
              <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember (2)" width="90" x="313" y="75">
              </operator>
              <connect from_port="single" to_op="Multiply" to_port="input"/>
              <connect from_op="Recall" from_port="result" to_op="Union" to_port="example set 1"/>
              <connect from_op="Multiply" from_port="output 1" to_op="Union" to_port="example set 2"/>
              <connect from_op="Multiply" from_port="output 2" to_port="output 1"/>
              <connect from_op="Union" from_port="union" to_op="Remember (2)" to_port="store"/>
              <portSpacing port="source_single" spacing="0"/>
            </process>
            <description align="center" color="transparent" colored="false" width="126">Then this</description>
          </operator>
          <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall (2)" width="90" x="514" y="435">
            <description align="center" color="transparent" colored="false" width="126">And lastly</description>
          </operator>
          <connect from_op="Data x = 1" from_port="output" to_op="Remember" to_port="store"/>
          <connect from_op="Data X = n" from_port="output" to_op="Collect" to_port="input 1"/>
          <connect from_op="Data X = n (2)" from_port="output" to_op="Collect" to_port="input 2"/>
          <connect from_op="Data X = n (3)" from_port="output" to_op="Collect" to_port="input 3"/>
          <connect from_op="Data X = n (4)" from_port="output" to_op="Collect" to_port="input 4"/>
          <connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/>
          <connect from_op="Loop Collection" from_port="output 1" to_port="result 2"/>
          <connect from_op="Recall (2)" from_port="result" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "sgenzer"
    Altair Employee
    Nice examples, and nice use of the new annotation feature!  ;)
    Why did I never notice the second output of the Loop Examples operator?  :o
    Scott
