<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_examples" compatibility="6.4.000" expanded="true" height="76" name="Loop Examples" width="90" x="246" y="120"> <process expanded="true"> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_values" compatibility="6.4.000" expanded="true" height="76" name="Loop Values" width="90" x="246" y="120"> <parameter key="attribute" value="label"/> <process expanded="true"> <connect from_port="example set" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="380" y="120"/> <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Data x = 1" width="90" x="112" y="120"/> <operator activated="true" class="generate_data" compatibility="5.3.015" expanded="true" height="60" name="Data X = n" width="90" x="112" y="255"/> <operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="94" name="Append" width="90" x="313" y="165"/> <operator activated="true" class="store" compatibility="5.3.015" expanded="true" height="60" name="Store" width="90" x="447" y="165"/> <connect from_op="Data x = 1" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Data X = n" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Store" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.4.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" breakpoints="after" class="loop_examples" compatibility="6.4.000" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="120"> <process expanded="true"> <connect from_port="example set" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="447" y="165"/> <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="loop_repository" compatibility="6.5.000" expanded="true" height="76" name="Loop Repository" width="90" x="45" y="30"> <parameter key="repository_folder" value="//Local Repository/LoopTest/"/> <parameter key="entry_type" value="IOObject"/> <process expanded="true"> <connect from_port="repository object" to_port="out 1"/> <portSpacing port="source_repository object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Select the desired repository folder (and optional filters)</description> </operator> <operator activated="true" class="append" compatibility="6.5.000" expanded="true" height="76" name="Append" width="90" x="179" y="30"> <description align="center" color="transparent" colored="false" width="126">Appends all ExampleSets of the input collection</description> </operator> <connect from_op="Loop Repository" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data x = 1" width="90" x="45" y="75"/> <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember" width="90" x="179" y="165"> <parameter key="name" value="mycollection"/> <description align="center" color="transparent" colored="false" width="126">This happens first to initialise the remember</description> </operator> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n" width="90" x="45" y="345"/> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (2)" width="90" x="45" y="435"> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (3)" width="90" x="45" y="525"> <parameter key="number_of_attributes" value="8"/> </operator> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Data X = n (4)" width="90" x="45" y="615"> <parameter key="number_of_attributes" value="10"/> </operator> <operator activated="true" class="collect" compatibility="6.4.000" expanded="true" height="130" name="Collect" width="90" x="179" y="480"/> <operator activated="true" class="loop_collection" compatibility="6.4.000" expanded="true" height="76" name="Loop Collection" width="90" x="380" y="435"> <process expanded="true"> <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall" width="90" x="112" y="30"> <parameter key="name" value="mycollection"/> </operator> <operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="112" y="390"/> <operator activated="true" class="union" compatibility="6.4.000" expanded="true" height="76" name="Union" width="90" x="179" y="165"/> <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember (2)" width="90" x="313" y="75"> <parameter key="name" value="mycollection"/> </operator> <connect from_port="single" to_op="Multiply" to_port="input"/> <connect from_op="Recall" from_port="result" to_op="Union" to_port="example set 1"/> <connect from_op="Multiply" from_port="output 1" to_op="Union" to_port="example set 2"/> <connect from_op="Multiply" from_port="output 2" to_port="output 1"/> <connect from_op="Union" from_port="union" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Then this</description> </operator> <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall (2)" width="90" x="514" y="435"> <parameter key="name" value="mycollection"/> <description align="center" color="transparent" colored="false" width="126">And lastly</description> </operator> <connect from_op="Data x = 1" from_port="output" to_op="Remember" to_port="store"/> <connect from_op="Data X = n" from_port="output" to_op="Collect" to_port="input 1"/> <connect from_op="Data X = n (2)" from_port="output" to_op="Collect" to_port="input 2"/> <connect from_op="Data X = n (3)" from_port="output" to_op="Collect" to_port="input 3"/> <connect from_op="Data X = n (4)" from_port="output" to_op="Collect" to_port="input 4"/> <connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 2"/> <connect from_op="Recall (2)" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
