rapid miner with dynamic web project
Hello,
I am using rapid miner 5.3 and eclipse integrated by github To run own application.
Integration is done successful. But while running .jsp file it shows errors.
Errors is in .java file where I wrote rapid miner process code. So my question is that rapid miner 5.3 and eclipse integration can work out in web project or I have to develop desktop for the same?
1 - 7 of
71
Hi,
I don't understand the question. Please have a look at the FAQ: http://rapid-i.com/rapidforum/index.php/topic,5807.0.html
If that does not help, could you clarify what you want to do?
Regards,
Marco
Regards,
Marco
Hello,
I am using eclipse for integration. so as per my view there should be no problem in AGPL. Am I right?
Another thing is I have downloaded repository from https://github.com/rapidminer/rapidminer this location.
So it is correct for my dynamic web project?
Please reply as soon as possible.
As I got error in some files. One of them is HTMLlat1.ent. Please resolve it as I stuck in this problem
yes you can use it in a web application. It needs to be initialized properly and then it should work. You do however need all the libraries found in the /libs folder.
Regards,
Marco
