"[SOLVED] Error when trying to start RapidMiner Server after installation"
Hallo,
I installed RapidMiner server on a CentOS server and I am getting the following error when I'm trying to start the service with standalon.sh:
01:49:51,399 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-15) MSC00001: Failed to start service jboss.serverManagement.controller.management.http: org.jboss.msc.service.StartException in service jboss.serverManagement.controller.management.http: java.io.IOException: Unable to load resource handler
at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:226) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [rt.jar:1.7.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [rt.jar:1.7.0_65]
at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_65]
Caused by: java.io.IOException: Unable to load resource handler
at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:212) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:190) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
... 5 more
Caused by: org.jboss.modules.ModuleNotFoundException: org.jboss.as.domain-http-error-context:main
at org.jboss.modules.ModuleLoader.loadModule(ModuleLoader.java:224) [jboss-modules.jar:1.2.0.CR1]
at org.jboss.as.domain.http.server.ResourceHandler.getClassLoader(ResourceHandler.java:327) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
at org.jboss.as.domain.http.server.ErrorHandler.<init>(ErrorHandler.java:54) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:210) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
... 6 more
Any help would be greatly appreciated.
... 5 more
... 6 more
1 - 17 of
171
Unfortunately not. When I run standalone.sh It terminates after about one and a half minutes with ...
01:51:15,886 INFO [javax.enterprise.resource.webcontainer.jsf.config] (ServerService Thread Pool -- 76) Initializing Mojarra 2.1.18-jbossorg-1 20130205-1414 for context '/RAWS'
./standalone.sh: line 217: 25619 Killed "/usr/lib/jvm/java/bin/java" -D"[Standalone]" -server -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml "-Dorg.jboss.boot.log.file=/home/metisuser/rapidminer/standalone/log/server.log" "-Dlogging.configuration=file:/home/metisuser/rapidminer/standalone/configuration/logging.properties" -jar "/home/metisuser/rapidminer/jboss-modules.jar" -mp "/home/metisuser/rapidminer/modules" -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir="/home/metisuser/rapidminer" -Djboss.server.base.dir="/home/metisuser/rapidminer/standalone"
Vielen Dank fuer die prompten Antworten.
Here's the server.log file:
21:58:57,598 INFO [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
21:58:59,817 INFO [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
21:59:00,111 INFO [org.jboss.as] (MSC service thread 1-6) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
21:59:00,147 DEBUG [org.jboss.as.config] (MSC service thread 1-6) Configured system properties:
[Standalone] =
awt.toolkit = sun.awt.X11.XToolkit
file.encoding = UTF-8
file.encoding.pkg = sun.io
file.separator = /
java.awt.graphicsenv = sun.awt.X11GraphicsEnvironment
java.awt.headless = true
java.awt.printerjob = sun.print.PSPrinterJob
java.class.path = /home/metisuser/rapidminer/jboss-modules.jar
java.class.version = 51.0
java.endorsed.dirs = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/endorsed
java.ext.dirs = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/ext:/usr/java/packages/lib/ext
java.home = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre
java.io.tmpdir = /tmp
java.library.path = /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.net.preferIPv4Stack = true
java.runtime.name = OpenJDK Runtime Environment
java.runtime.version = 1.7.0_65-mockbuild_2014_07_16_06_06-b00
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.7
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.7.0_65
java.vm.info = mixed mode
java.vm.name = OpenJDK 64-Bit Server VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.7
java.vm.vendor = Oracle Corporation
java.vm.version = 24.65-b04
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = /home/metisuser/rapidminer
jboss.host.name = metis
jboss.modules.dir = /home/metisuser/rapidminer/modules
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = metis
jboss.qualified.host.name = metis.richeyint.com
jboss.server.base.dir = /home/metisuser/rapidminer/standalone
jboss.server.config.dir = /home/metisuser/rapidminer/standalone/configuration
jboss.server.data.dir = /home/metisuser/rapidminer/standalone/data
jboss.server.default.config = standalone.xml
jboss.server.deploy.dir = /home/metisuser/rapidminer/standalone/data/content
jboss.server.log.dir = /home/metisuser/rapidminer/standalone/log
jboss.server.name = metis
jboss.server.persist.config = true
jboss.server.temp.dir = /home/metisuser/rapidminer/standalone/tmp
line.separator =
logging.configuration = file:/home/metisuser/rapidminer/standalone/configuration/logging.properties
module.path = /home/metisuser/rapidminer/modules
org.jboss.boot.log.file = /home/metisuser/rapidminer/standalone/log/server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = amd64
os.name = Linux
os.version = 2.6.32-042stab092.2
path.separator = :
sun.arch.data.model = 64
sun.boot.class.path = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/resources.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/rt.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jsse.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jce.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/charsets.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/rhino.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jfr.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/classes
sun.boot.library.path = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/amd64
sun.cpu.endian = little
sun.cpu.isalist =
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = /home/metisuser/rapidminer/jboss-modules.jar -mp /home/metisuser/rapidminer/modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=/home/metisuser/rapidminer -Djboss.server.base.dir=/home/metisuser/rapidminer/standalone
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = UTF-8
sun.management.compiler = HotSpot 64-Bit Tiered Compilers
sun.os.patch.level = unknown
sun.rmi.dgc.client.gcInterval = 3600000
sun.rmi.dgc.server.gcInterval = 3600000
user.country = US
user.dir = /home/metisuser/rapidminer/bin
user.home = /root
user.language = en
user.name = root
user.timezone = America/Chicago
21:59:00,150 DEBUG [org.jboss.as.config] (MSC service thread 1-6) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/home/metisuser/rapidminer/standalone/log/server.log -Dlogging.configuration=file:/home/metisuser/rapidminer/standalone/configuration/logging.properties
21:59:04,799 INFO [org.jboss.as.server.deployment.scanner] (DeploymentScanner-threads - 1) JBAS015003: Found ROOT.war in deployment directory. To trigger deployment create a file called ROOT.war.dodeploy
21:59:04,831 INFO [org.xnio] (MSC service thread 1-27) XNIO Version 3.0.7.GA
21:59:04,835 INFO [org.jboss.as.server] (Controller Boot Thread) JBAS015888: Creating http management service using socket-binding (management-http)
21:59:04,840 INFO [org.xnio.nio] (MSC service thread 1-27) XNIO NIO Implementation Version 3.0.7.GA
21:59:04,881 INFO [org.jboss.remoting] (MSC service thread 1-27) JBoss Remoting version 3.2.14.GA
21:59:04,978 INFO [org.jboss.as.configadmin] (ServerService Thread Pool -- 27) JBAS016200: Activating ConfigAdmin Subsystem
21:59:04,981 INFO [org.jboss.as.naming] (ServerService Thread Pool -- 39) JBAS011800: Activating Naming Subsystem
21:59:04,985 INFO [org.jboss.as.webservices] (ServerService Thread Pool -- 50) JBAS015537: Activating WebServices Extension
21:59:04,985 INFO [org.jboss.as.security] (ServerService Thread Pool -- 45) JBAS013171: Activating Security Subsystem
21:59:04,982 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 32) JBAS010280: Activating Infinispan subsystem.
21:59:05,009 INFO [org.jboss.as.security] (MSC service thread 1-2) JBAS013170: Current PicketBox version=4.0.15.Final
21:59:05,017 INFO [org.jboss.as.jsf] (ServerService Thread Pool -- 49) JBAS012605: Activated the following JSF Implementations: [main, 1.2]
21:59:05,043 INFO [org.jboss.as.connector.logging] (MSC service thread 1-6) JBAS010408: Starting JCA Subsystem (JBoss IronJacamar 1.0.15.Final)
21:59:05,054 INFO [org.jboss.as.osgi] (ServerService Thread Pool -- 40) JBAS011906: Activating OSGi Subsystem
21:59:05,717 INFO [org.jboss.as.naming] (MSC service thread 1-1) JBAS011802: Starting Naming Service
21:59:05,781 INFO [org.jboss.as.mail.extension] (MSC service thread 1-16) JBAS015400: Bound mail session [java:/Mail]
21:59:05,959 INFO [org.jboss.as.connector.subsystems.datasources] (ServerService Thread Pool -- 28) JBAS010404: Deploying non-JDBC-compliant driver class com.mysql.jdbc.Driver (version 5.1)
21:59:07,402 INFO [org.apache.coyote.http11] (MSC service thread 1-27) JBWEB003001: Coyote HTTP/1.1 initializing on : http-/0.0.0.0:7000
21:59:07,500 INFO [org.apache.coyote.http11] (MSC service thread 1-27) JBWEB003000: Coyote HTTP/1.1 starting on: http-/0.0.0.0:7000
21:59:07,782 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-10) JBAS010400: Bound data source [java:/jdbc/RapidAnalyticsDS]
21:59:08,014 INFO [org.jboss.ws.common.management] (MSC service thread 1-13) JBWS022052: Starting JBoss Web Services - Stack CXF Server 4.1.3.Final
21:59:08,210 INFO [org.jboss.as.server.deployment.scanner] (MSC service thread 1-26) JBAS015012: Started FileSystemDeploymentService for directory /home/metisuser/rapidminer/standalone/deployments
21:59:08,223 INFO [org.jboss.as.server.deployment] (MSC service thread 1-5) JBAS015876: Starting deployment of "rapidminer-server-ear-2.1.0-ear.ear" (runtime-name: "rapidminer-server-ear-2.1.0-ear.ear")
21:59:08,223 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015876: Starting deployment of "ROOT.war" (runtime-name: "ROOT.war")
21:59:08,247 INFO [org.jboss.as.remoting] (MSC service thread 1-14) JBAS017100: Listening on 0.0.0.0:4447
21:59:08,247 INFO [org.jboss.as.remoting] (MSC service thread 1-30) JBAS017100: Listening on 209.188.88.190:9999
21:59:08,252 WARN [org.jboss.as.domain.http.api] (MSC service thread 1-22) JBAS015102: Unable to load console module for slot main, disabling console
21:59:08,255 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-22) MSC00001: Failed to start service jboss.serverManagement.controller.management.http: org.jboss.msc.service.StartException in service jboss.serverManagement.controller.management.http: java.io.IOException: Unable to load resource handler
... 5 more
... 6 more
There is more but if I add it, it'll go over the maximum allowed length (20000 characters). I'd be happy to email it to you though.
[Standalone] =
file.separator = /
line.separator =
os.arch = amd64
os.name = Linux
path.separator = :
sun.cpu.isalist =
user.country = US
user.home = /root
user.language = en
user.name = root
... 5 more
... 6 more
Hi,
feel free to use something like http://pastebin.com/. The intersting part is missing in your log
Regards,
Marco
Regards,
Marco
Was just thinking of that before I saw your reply: http://pastebin.com/my5cCLy5
Hi,
the good news is, there is no error whatsoever in your log. The bad news is it seems to be stuck on
I have seen this before but we were never able to reproduce this. What version of CentOS are you using exactly?
Regards,
Marco
How long did you wait after starting the server before copying the log?
21:59:39,129 INFO [javax.enterprise.resource.webcontainer.jsf.config] (ServerService Thread Pool -- 67) Initializing Mojarra 2.1.18-jbossorg-1 20130205-1414 for context '/RA'
Regards,
Marco
I am on "CentOS release 6.5 (Final)". Here's the console output when I run standalone.sh: http://pastebin.com/njHcbTHk
This is what I get when I run "cat /proc/meminfo"
root@metis [1065 03:06:48 /home/metisuser/rapidminer/bin]# cat /proc/meminfo
MemTotal: 1572864 kB
MemFree: 953088 kB
Cached: 4484 kB
Buffers: 0 kB
Active: 134800 kB
Inactive: 440124 kB
Active(anon): 134496 kB
Inactive(anon): 435944 kB
Active(file): 304 kB
Inactive(file): 4180 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 131072 kB
SwapFree: 168 kB
Dirty: 92 kB
Writeback: 0 kB
AnonPages: 570440 kB
Shmem: 6756 kB
Slab: 44772 kB
SReclaimable: 15968 kB
SUnreclaim: 28804 kB
MemFree: 953088 kB
Cached: 4484 kB
Buffers: 0 kB
Active: 134800 kB
Inactive: 440124 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapFree: 168 kB
Dirty: 92 kB
Writeback: 0 kB
Shmem: 6756 kB
Slab: 44772 kB
As well as ...
top - 03:11:31 up 40 days, 11:50, 1 user, load average: 0.23, 0.54, 0.69
Tasks: 73 total, 1 running, 72 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.0%us, 0.0%sy, 0.0%ni,100.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 1572864k total, 886284k used, 686580k free, 0k buffers
Swap: 131072k total, 79456k used, 51616k free, 219696k cached
Hi,
I can't say it with certainty, but your low memory might be the source for the problem. I'd recommend to have at least 2 GB of free memory available when starting RM Server with a Starter license (more for bigger licenses). While it may run on some machines with less than 1 GB of free memory, it may not on others.
Regards,
Marco
Regards,
Marco
this "error" occurs for some installations while it does not for others. In either case however there is no actual problem and it can be safely ignored. While it does look a bit scary, your server should work just fine, correct?
Regards,
Marco
