🎉Community Raffle - Win $25
Join and Win
"[SOLVED] Error when trying to start RapidMiner Server after installation"
User: "koepfw"
New Altair Community Member
Updated by Jocelyn
Hallo,
I installed RapidMiner server on a CentOS server and I am getting the following error when I'm trying to start the service with standalon.sh:
01:49:51,399 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-15) MSC00001: Failed to start service jboss.serverManagement.controller.management.http: org.jboss.msc.service.StartException in service jboss.serverManagement.controller.management.http: java.io.IOException: Unable to load resource handler
       at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:226) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
       at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [rt.jar:1.7.0_65]
       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [rt.jar:1.7.0_65]
       at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_65]
Caused by: java.io.IOException: Unable to load resource handler
       at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:212) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:190) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       ... 5 more
Caused by: org.jboss.modules.ModuleNotFoundException: org.jboss.as.domain-http-error-context:main
       at org.jboss.modules.ModuleLoader.loadModule(ModuleLoader.java:224) [jboss-modules.jar:1.2.0.CR1]
       at org.jboss.as.domain.http.server.ResourceHandler.getClassLoader(ResourceHandler.java:327) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.domain.http.server.ErrorHandler.<init>(ErrorHandler.java:54) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:210) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       ... 6 more
Any help would be greatly appreciated.
